need help setting up comparators in PIC18F87J10
zilog
PostPosted: Wed Jun 27, 2007 5:59 am     Reply with quote
I want Comparator 1 together with the internal voltage reference to input a signal on RF5, compare it with Vref ~0.5V, and output the result on pin RF2.
I have tried with the code below with no success - what am I doing wrong? The problem manifests itself that no matter what input level on RF5, I always get logic high on RF2.
#byte CVRCON = 0xFB5
#byte CMCON  = 0xFB4
set_tris_f(~0x04); //RF2 as output
CVRCON = 0xA5;
CMCON = 0x1E;
zilog
PostPosted: Wed Jun 27, 2007 6:00 am     Reply with quote
I forgot to mention that Vdd-Vss = 2.5V in my application.
Kenny
PostPosted: Wed Jun 27, 2007 6:11 pm     Reply with quote
The configuration that you have setup has no output to a port pin.
C1OUT is a bit in CMCON (see data sheet Fig. 21-1).
BTW the CCS constants defined in 18F87J10.h would make the code easier to read and see this kind of problem.
