Non black box LCD problem!!! (%u fails)
micromouse
PostPosted: Sun Jun 24, 2007 5:14 am     Reply with quote
I'm using CCS with MPLAB 7.5 on an ICD2 programming a simple 8x2 POWERTIP LCD.
The following code works, but when I try to print using anything else than %X I get blank lines and the code fails. I have looked at timing issues, check all connections, am now wondering if there is something really strange going on.
Code that works
#include <16F648A.h>
#device   ICD=TRUE
#fuses INTRC,NOWDT,NOPROTECT,NOLVP
#use delay(clock=4MHz)
#include <lcd.c>
   int value;
   lcd_init();
   value=1;
   while (1)
      printf(lcd_putc,"\fX:%X %X\n",value,value);
      printf(lcd_putc,"H: %X",value);
      value=value+1;
The result of this code is
X:56 56
H: 56
and the values count up as they should.
However if I change the %X to %u I get the following
X:1 1
and nothing else.
Any ideas? Have tried both the CCS and the flex LCD drivers with the same result.
Wayne
micromouse
Futher along the line
PostPosted: Sun Jun 24, 2007 5:27 am     Reply with quote
Have now tried the code on an 887 board with a 16x2 LCD mapped in an identical manner and everything works. it appears that the mapping for an 8x2 is causing an issue????
Wayne
PostPosted: Sun Jun 24, 2007 1:09 pm     Reply with quote
Post the part number of the PowerTip LCD. I'll look at the memory
map in the data sheet.
In this post, I test several 8x2 LCDs with the "Flex" driver and they
all work.
http://www.ccsinfo.com/forum/viewtopic.php?t=29819&start=3
Flex driver:
http://www.ccsinfo.com/forum/viewtopic.php?t=24661
