timer0
jmofthenorth
timer0
PostPosted: Fri Jun 22, 2007 9:40 am     Reply with quote
I am using a 18F2550 PIC and would like to set up the timer so that it counts to a 16 bit number, and takes an external clock. How do I do this?
if I leave out - > RTCC_8_BIT from the setup_timer0(mode) is it automatically 16 bit?
thanks
Jesse
PostPosted: Fri Jun 22, 2007 1:10 pm     Reply with quote
I leave out - > RTCC_8_BIT from the setup_timer_0(mode) is it automatically 16 bit?
Yes, that's right.
Look in the .H file for your PIC. In the Timer0 (RTCC) section, it lists
the constants that can be used with the setup_timer_0() function.
You will see the constants that allow you to specify External clock mode.
