function passing pin no ?
deepakomanna
View user's profile Send private message AIM Address Yahoo Messenger
PostPosted: Fri Jun 22, 2007 3:39 am     Reply with quote
Dear Sir,
here i am using 12f629, MPLAB 7.5 Ver. & CCS PCM C Compiler, Version 3.249, 34534.
can i use a function like this
void SCR_ON(int8);
SCR_ON(PIN_A2);   // calling function
SCR_ON(PIN_A4);
void SCR_ON(int8 trigger)
   OUTPUT_HIGH(trigger);
   DELAY_US(60);
   OUTPUT_LOW(trigger);
Thank You,
With Best Regards,
Deepak.
inservi
PostPosted: Fri Jun 22, 2007 8:58 am     Reply with quote
why not use output_bit (pin, value) ?
like
int16 i=PIN_B0;
output_bit(i,1);
void SCR_ON(int16);
SCR_ON(PIN_A4);
void SCR_ON(int16 trigger)
   OUTPUT_BIT(trigger,1);
   DELAY_US(60);
   OUTPUT_BIT(trigger,0);
I think that int16 or int8 is depending on witch PIC used ?
dro.
in médio virtus
SherpaDoug
PostPosted: Fri Jun 22, 2007 9:20 am     Reply with quote
One of these should lead you in the right direction:
For 16F:
http://www.ccsinfo.com/forum/viewtopic.php?t=25280&start=4
For 18F:
http://www.ccsinfo.com/forum/viewtopic.php?t=27723&start=3
Thank PCM programmer
inservi
PostPosted: Fri Jun 22, 2007 10:27 am     Reply with quote
Thank-you SherpaDoug,
Why make so complicated when output_bit (pin, value) work well ?
(for 12F629, int8 must working because addresses of A0 to A5 are 40 to 45).
dro.
in médio virtus
SherpaDoug
PostPosted: Fri Jun 22, 2007 12:03 pm     Reply with quote
I get the error "Expression must evaluate to a constant" with output_bit (pin, value) where pin is an int.
PostPosted: Fri Jun 22, 2007 1:02 pm     Reply with quote
It depends on the compiler version. CCS added the ability to use a
variable for the pin parameter in version 4 of the compiler.
I don't know the exact version in which it became available, but I tested
version 4.042 and it does compile OK in that version.
Those two routines that Sherpa Doug linked to are for people who
have version 3.xxx and earlier (that's a lot of people).
