Rs485 Wait_for_Bus
Dave Clark
Rs485 Wait_for_Bus
PostPosted: Tue Jun 19, 2007 12:00 pm     Reply with quote
Hello all,
I have a ittle trouble with RS485, i would like to block RS485 transfer when i like. I mean not disable the RS485, but do something so that everybody on the RS485 line sees it has busy , so that when i use "wait_for_bus" everybody waits.
utils i decide to free it again.
I tryed to output_high(RS485_ENABLE_PIN) and RS485_TX_PIN
void rs485_wait_for_bus(int1 clrwdt)
   int16 i;
   RCV_OFF();
   for(i=0; i <= (rs485_wait_time*20); ++i)
      if(!input(RS485_RX_PIN))
         i = 0;
         delay_us(50);
      if(clrwdt)
         restart_wdt();
any help ? or idear ?
Neutone
Re: Rs485 Wait_for_Bus
PostPosted: Tue Jun 19, 2007 12:40 pm     Reply with quote
A 485 Bus is not intended to be driven from more than one device at a time. You need a Protocol to keep this from happening.
PostPosted: Wed Jun 20, 2007 2:00 am     Reply with quote
first thx, for answer.
second, damn ....
is there a way to send a message to ALL id's ?
SherpaDoug
PostPosted: Wed Jun 20, 2007 8:54 am     Reply with quote
It all depends on the protocol YOU write. RS485 just specifies the voltages on the wires, not the bits that go on them. If each node checks for a Stop bit condition before talking, and one node sets a Start bit condition and holds it, then everyone will eventually stop and stare at the line waiting for a Stop bit. Is this what you are looking for?
PostPosted: Thu Jun 21, 2007 1:06 am     Reply with quote
yes this is something like this i was looking for. I forgot to say that i am using the RS485.c provided by CCS. I am going to take a look at modbus.c provided too.
thank you
