mlanglais
| Warning 216 |
Posted: Wed Jun 20, 2007 12:56 pm |
Hi
I have written an isr. All was fine, but suddently, it pops me warning 216 [@MUL1616].
This is the code
int16 ga;
int16 gb;
SomeStruct gs[5][128] = {...}
#int_timer3
vois isr_timer3(void)
SomeStruct* p;
p = &gs[ga][gb];
The faulty line is
If I change it to something that do the same work | Code: | | p = gs + ga * 128 + gb; | the error is gone.
Why ? |
Posted: Wed Jun 20, 2007 1:33 pm |
You need to post a compilable test program, showing all variable
declarations, #include, #fuses, etc., statements.
Also post your compiler version. |
Posted: Thu Jun 21, 2007 3:14 am |
The warning, is a 'classic'. It ties up with the PIC, not allowing reentrancy to a function (you can't call a function inside itself), and so, if a function is called inside an interrupt, then interrupts are disabled around the same function used outside the interrupt, with this warning being given.
The function concerned here, is the 16*16bit multiplier routine.
Your 'alternative' line, though it appears the same, will code totally differently. The compiler is 'smart' with regards to *128 (and any binary multiplication), and knows this can be replaced, with a seven bit left shift, when dealing with a 'constant'. Hence it does so. However, when dealing with the 'array', a standardised array access routine is used, which uses the multiplication code.
In fact the replacement, will be faster/smaller, and avoid the re-entrancy problem!.
