write_program_memory: only working for bootloader
MVS1
PostPosted: Wed Jun 20, 2007 1:17 pm     Reply with quote
pic: PIC18F2580
clock: 20MHz
compiler: PCH 4.004
In the past, I have used the bootloader program that comes with CCS and it works. (more specifically, the write_program_memory() works)
Now, I'm trying to use the program memory for somewhat static storage but I can't get this function to work. The address is at a multiple of FLASH_ERASE_SIZE.
The output is
Start
255 255 255 255 255 255 255 255 255 255 255 255 255 255 255 255 Done
My sample code and listing are below
#include <18F2580.h>
#use rs232(baud=115200, xmit=PIN_C6, rcv=PIN_C7)
   int8 count,i;
   int32 addr;
   int8 data[16] = {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15};
   int8 data_read[16];
   printf("Start\n\r");
   count = 16;
   addr = 0x1000;
   write_program_memory(addr, data, count);
   read_program_memory(addr, data_read, count);
   for (i = 0; i < count; i++)
      printf("%u ", data_read[i]);
   printf("Done\n\r");
CCS PCH C Compiler, Version 4.004, 34880               20-Jun-07 11:47
               Filename: C:\PicFiles\memprog.lst
               ROM used: 494 bytes (2%)
                         Largest free fragment is 32274
               RAM used: 44 (3%) at main() level
                         49 (3%) worst case
               Stack:    2 locations
0000:  GOTO   00EE
0038:  MOVFF  2D,01
003C:  MOVFF  2C,00
0040:  TSTFSZ 2C
0042:  INCF   01,F
0044:  TBLRD*+
0046:  MOVFF  FF5,FEE
004A:  DECFSZ 00,F
004C:  BRA    0044
004E:  DECFSZ 01,F
0050:  BRA    0044
0052:  CLRF   FF8
0054:  GOTO   01A2 (RETURN)
.................... #include <18F2580.h>
.................... //////// Standard Header file for the PIC18F2580 device ////////////////
.................... #device PIC18F2580
.................... #list
.................... #fuses HS,NOWDT,NOPROTECT,NOLVP
.................... #use delay(clock=20000000)
0034:  GOTO   0188 (RETURN)
.................... #use rs232(baud=115200, xmit=PIN_C6, rcv=PIN_C7)
.................... void main()
00EE:  CLRF   FF8
00F0:  BCF    FD0.7
00F2:  CLRF   FEA
00F4:  CLRF   FE9
00F6:  BSF    FB8.3
00F8:  MOVLW  2A
00FA:  MOVWF  FAF
00FC:  MOVLW  00
00FE:  MOVWF  FB0
0100:  MOVLW  A6
0102:  MOVWF  FAC
0104:  MOVLW  90
0106:  MOVWF  FAB
0108:  MOVF   FC1,W
010A:  ANDLW  C0
010C:  IORLW  0F
010E:  MOVWF  FC1
....................    int8 count,i;
....................    int32 addr;
....................    int8 data[16] = {0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15};
0110:  CLRF   0C
0112:  MOVLW  01
0114:  MOVWF  0D
0116:  MOVLW  02
0118:  MOVWF  0E
011A:  MOVLW  03
011C:  MOVWF  0F
011E:  MOVLW  04
0120:  MOVWF  10
0122:  MOVLW  05
0124:  MOVWF  11
0126:  MOVLW  06
0128:  MOVWF  12
012A:  MOVLW  07
012C:  MOVWF  13
012E:  MOVLW  08
0130:  MOVWF  14
0132:  MOVLW  09
0134:  MOVWF  15
0136:  MOVLW  0A
0138:  MOVWF  16
013A:  MOVLW  0B
013C:  MOVWF  17
013E:  MOVLW  0C
0140:  MOVWF  18
0142:  MOVLW  0D
0144:  MOVWF  19
0146:  MOVLW  0E
0148:  MOVWF  1A
014A:  MOVLW  0F
014C:  MOVWF  1B
....................    int8 data_read[16];
....................    printf("Start\n\r");
014E:  CLRF   2C
0150:  MOVF   2C,W
0152:  RCALL  0004
0154:  INCF   2C,F
0156:  MOVWF  00
0158:  MOVF   00,W
015A:  BTFSS  F9E.4
015C:  BRA    015A
015E:  MOVWF  FAD
0160:  MOVLW  07
0162:  SUBWF  2C,W
0164:  BNZ   0150
....................    count = 16;
0166:  MOVLW  10
0168:  MOVWF  06
....................    addr = 0x1000;
016A:  CLRF   0B
016C:  CLRF   0A
016E:  MOVWF  09
0170:  CLRF   08
....................    write_program_memory(addr, data, count);
0172:  MOVFF  09,2D
0176:  MOVFF  08,2C
017A:  CLRF   2F
017C:  MOVLW  0C
017E:  MOVWF  2E
0180:  CLRF   31
0182:  MOVFF  06,30
0186:  BRA    0034
....................    read_program_memory(addr, data_read, count);
0188:  MOVFF  0A,FF8
018C:  MOVFF  09,FF7
0190:  MOVFF  08,FF6
0194:  CLRF   FEA
0196:  MOVLW  1C
0198:  MOVWF  FE9
019A:  CLRF   2D
019C:  MOVFF  06,2C
01A0:  BRA    0038
....................    for (i = 0; i < count; i++)
01A2:  CLRF   07
01A4:  MOVF   06,W
01A6:  SUBWF  07,W
01A8:  BC    01D2
....................       printf("%u ", data_read[i]);
01AA:  CLRF   03
01AC:  MOVF   07,W
01AE:  ADDLW  1C
01B0:  MOVWF  FE9
01B2:  MOVLW  00
01B4:  ADDWFC 03,W
01B6:  MOVWF  FEA
01B8:  MOVFF  FEF,2C
01BC:  MOVFF  2C,2D
01C0:  MOVLW  1B
01C2:  MOVWF  2E
01C4:  BRA    0080
01C6:  MOVLW  20
01C8:  BTFSS  F9E.4
01CA:  BRA    01C8
01CC:  MOVWF  FAD
01CE:  INCF   07,F
01D0:  BRA    01A4
....................    printf("Done\n\r");
01D2:  CLRF   2C
01D4:  MOVF   2C,W
01D6:  RCALL  001C
01D8:  INCF   2C,F
01DA:  MOVWF  00
01DC:  MOVF   00,W
01DE:  BTFSS  F9E.4
01E0:  BRA    01DE
01E2:  MOVWF  FAD
01E4:  MOVLW  06
01E6:  SUBWF  2C,W
01E8:  BNZ   01D4
....................    while(1);
01EA:  BRA    01EA
01EC:  SLEEP
Configuration Fuses:
   Word  1: 0200   HS NOIESO NOFCMEN RESERVED
   Word  2: 1E1E   BROWNOUT NOWDT BORV21 PUT WDT32768
   Word  3: 8200   PBADEN NOLPT1OSC MCLR RESERVED
   Word  4: 0081   STVREN NODEBUG NOLVP BBSIZ1K NOXINST RESERVED
   Word  5: C00F   NOPROTECT NOCPD NOCPB
   Word  6: E00F   NOWRT NOWRTD NOWRTC NOWRTB
   Word  7: 400F   NOEBTR NOEBTRB
[/quote][/code]
PostPosted: Wed Jun 20, 2007 1:25 pm     Reply with quote
compiler: PCH 4.004
This version is too early.
MVS1
PostPosted: Wed Jun 20, 2007 1:54 pm     Reply with quote
PCM programmer wrote:
compiler: PCH 4.004
What do you mean? Does V4.004 not support write_program_memory()?
PostPosted: Wed Jun 20, 2007 2:01 pm     Reply with quote
I mean that the consenus on this board is that vs. 4.004
is too early in the v4 release cycle to be a reliable version.
CCS versions page:
http://www.ccsinfo.com/devices.php?page=versioninfo
