RA4/TOCKI readout hangs
cyberant
PostPosted: Mon Jun 18, 2007 4:08 am     Reply with quote
I have a problem with RA4/TOCKI Sad
I have a switch on RA4 which switches RA4 to high or low. I try`d my programm with the switch on RA3/AN3 und it works without a problem, but as soon as i connect the switch to ra4 und press it my programm stops and i have no reaction on my RS232 imputs anymore.
Do i have to set RA4 in analog mode or something like this?
Ive allready done: "setup_adc_ports(AN0)"
and my programm works with RA3/AN3 - i suggest the problem must be something with the TOCKI function of RA4 - how can I set RA4/TOCKI to work as a normal digital input? (I already try`d the search function...)
inservi
PostPosted: Mon Jun 18, 2007 4:23 am     Reply with quote
What device do you use ?
With some pic as 18f252, the RA4 is different than other RA.
Here is the description from Microchip data sheet
The RA4 pin is multiplexed with the Timer0 module
clock input to become the RA4/T0CKI pin. The RA4/
T0CKI pin is a Schmitt Trigger input and an open drain
output. All other RA port pins have TTL input levels and
full CMOS output drivers.
Your problem is probably the way you pull up the pin.
As the A4 pin is a Schmitt Trigger input, it need 4V for logic 1.
How did you connected you switch ?
Best regards,
dro.
in médio virtus
cyberant
PostPosted: Mon Jun 18, 2007 6:05 am     Reply with quote
My switch works correctly - switches between 0-4V (works without problems in AN3).
I use the PIC 16F877
Looks like I found the problem:
if i enable global interrupts the problem happens. Without this it works fine. But I didn`t write any interrupt routine - so its strange that it doesn`t jump out of the interrupt - or??
inservi
PostPosted: Mon Jun 18, 2007 8:43 am     Reply with quote
Could-you send the complete configuration ?
dro
in médio virtus
cyberant
PostPosted: Mon Jun 18, 2007 11:49 am     Reply with quote
What complete Configuration do u need? I have try`d the switch - works fine on AN3(its no Hardware Problem) but not on AN4 with enable_interrupts(GLOBAL);
I think because it jumps into the interrupt and dont go back into the normal Programm - but Ive not wrote a Interrupt Service Routine or something...
PostPosted: Mon Jun 18, 2007 12:54 pm     Reply with quote
Er.
If you enable interrupts, you _must_ have an interrupt handler (there is no point in enabling interrupts, unless you do have a handler, and without a handler present, with the interrupts enabled, the _hardware_, will jump to the handler, _which is not there..._).
