I would like to set a pin H in the PIC. However I determine which pin to set H programatically with something like:
output_high(var1);
where var1 is determined by the program.
PICC gives me an error: "Expressions must evaluate to a constant"
Can someone please tell me how to do this? (without using "if" loops)
Thank you in advance.
Regards
a.
Posted: Sat Jun 16, 2007 2:39 am
How about searching the forum!....
A search on 'How to use output_bit or output_high with a variable', will find one of the dozens of threads where a solution for this has been posted (including pointers to a couple of other threads).
