PWM - Pulse Width Modulation issues
LearningPIC
PostPosted: Fri Jun 15, 2007 8:13 pm     Reply with quote
I'm trying to get PWM working. I am using a Tower Hobbies system 3000 (STD TS-53) servo motor. I figure this should be easy enough to do. I tried two ways to do this. One I used the code below which should correspond to 50Hz and 7% duty cycle. However the motor just grinds for a few seconds, then squeeks and doesn't do much. I tried varrying the frequencies and duty cycles. But according to the datasheet and other people that used this motor 50Hz and 7% should work.
I even tried using a delay of 2ms for outputing PIN_B7 on and then a delay of 18ms for leaving PIN_B7 low. But once again, does not work and the worst part is that I can't produce consistent results. Anyone have an idea what might be wrong?
#include <16F877A.h>
#fuses HS
setup_timer_2(T2_DIV_BY_1, 99999, 1);
set_pwm1_duty(28000);
setup_ccp1(CCP_PWM);
} // Prevent PIC from going to sleep.
RA
PostPosted: Fri Jun 15, 2007 8:32 pm     Reply with quote
In PWM mode the pic16f877A is only capable of 10 bits of PWM resolution
(0-1023).
Your values exceed that of the hardware.
Also, at 20Mhz and div/16 prescaler the lowest possible repetition rate is 1.22Khz.
You could possibly use an interrupt driven software PWM or substantially lower your clock frequency if you wish to use the hardware PWM with 10 bit of resolution.
-Richard
PostPosted: Fri Jun 15, 2007 8:33 pm     Reply with quote
Download the CCS manual and look at the allowable size of the
parameters that can be used with the setup_timer_2() function
and the set_pwm1_duty() function. Link to CCS manual:
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
A key point is: This compiler is used with small microcontrollers.
The typical data type is an unsigned 8-bit number. This is not MSVC++.
Sometimes larger data types are used, but not often, with the PIC
hardware modules. If you keep that in mind, you will do well.
LearningPIC
PostPosted: Fri Jun 15, 2007 9:17 pm     Reply with quote
Ok so I can't get the hardware to count high enough unless I maybe cascade more than one timer together?
My other question is, couldn't I just use the following code:
#fuses HS
set_tris_b(0);
output_high(PIN_B7);
delay_ms(2);
delay_ms(18);
That should be enough to make the motor have a 2ms pulse with 20ms period (50 Hz frequency). Or is there something about using delays that won't make this work as I intend?
PostPosted: Fri Jun 15, 2007 9:32 pm     Reply with quote
You have to use software PWM to get a low frequency like 50 Hz.
http://www.ccsinfo.com/forum/viewtopic.php?t=20050
PostPosted: Fri Jun 15, 2007 11:15 pm     Reply with quote
I'm assuming this code should give me a frequency of 50Hz and a duty cycle of 8.2%. However when I run it, it does not produce the result I am expecting. Motor is trying to turn, but it can't. If only I could get my hands on an oscilliscope.
#include <16F877A>
#fuses HS
#use delay(clock = 20000000)
#define PWM_PIN  PIN_B1
#define LOOPCNT 390
int8 width;
#INT_RTCC
void tick_interrupt(void);
main()
width = 32;
setup_counters(RTCC_INTERNAL | RTCC_8_BIT, RTCC_DIV_1);
enable_interrupts(INT_RTCC);
#INT_RTCC
static int8 loop = LOOPCNT;
static int8 pulse;
if(--loop == 0)
   loop = LOOPCNT;
   pulse = width;
if(pulse)
   output_high(PWM_PIN);
   pulse--;
   output_low(PWM_PIN);
PostPosted: Sat Jun 16, 2007 2:05 am     Reply with quote
#define LOOPCNT 390
You need to learn your data types. What's the largest value an
unsigned 8-bit integer (int8) can hold ?
Also, you need to add NOLVP to your #fuses statement.
Without it, you risk having random lockups of the PIC.
LearningPIC
PostPosted: Sat Jun 16, 2007 8:46 am     Reply with quote
I modified static int8 loop = LOOPCNT; to static int16 loop = LOOPCNT; I added NOLVP. However the motor has the same problems as before, just jittering in the same spot. Thanks for all your help.
I guess the only thing left for me to do is to find an oscilliscope to make sure that I'm getting the correct output. If that is not the problem, then maybe try and find a function generator.
#include <16F877A>
#fuses HS, NOLVP
#define LOOPCNT 390
int8 width;
#INT_RTCC
main()
width = 20;
#INT_RTCC
static int8 pulse;
if(--loop == 0)
   loop = LOOPCNT;
   pulse = width;
if(pulse)
   pulse--;
PostPosted: Sun Jun 17, 2007 2:33 pm     Reply with quote
I tested your latest code posted above, on a PicDem2-Plus board.
I get an approximately 50 Hz waveform, with a 5% duty-cycle positive
pulse (1 ms). I tested this with vs. 4.041 of the compiler. So, it is
working.
LearningPIC
PostPosted: Mon Jun 18, 2007 12:53 pm     Reply with quote
I just checked on the oscilliscope and it worked fine. I also learned out why it wouldn't work properly Smile I'm so dumb. The motor I used I received from a friend and didn't know it wasn't a continuous rotation motor. I never even imagined anything else. But once I realized that, I found out that it does work properly. Thanks for your help PCM Programmer.
LearningPIC
PostPosted: Mon Jun 18, 2007 4:42 pm     Reply with quote
I spoke too soon. When I try it with the PIC it still doesn't work properly. I'm guessing that the way I have it setup the frequency is 50.08Hz, and this thing need an exact frequency to work properly. I'll have to find a way to increase the resolution.
PostPosted: Mon Jun 18, 2007 5:04 pm     Reply with quote
I guess I didn't read your initial post very carefully. You're actually
just trying to drive a servo.
This is the TS-53 servo:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXUK84
Here is a project page which shows how use that servo.
It has oscillscope waveforms.
http://www.dprg.org/projects/2003-05a/
CCS has a servo driver program. Here's the filename and location:
c:\Program Files\Picc\Drivers\Servos.c
Here's a demo program for it. The servo output pins are defined
near the start of the Servos.c file. The default pins are D6 and D7.
I tested the program below with PCM vs. 4.041 and it works.
You can see the servo pulses on pins D6 and D7 of the PIC.
#include <16F877.h>
#use delay(clock = 4000000)
#include <servos.c>
init_servos();
   set_servo(LEFT,  FORWARD, 2);
   set_servo(RIGHT, FORWARD, 3);
   set_servo(LEFT,  FORWARD, 1);
   set_servo(RIGHT, FORWARD, 2);
