ICSP and Reset chips
SherpaDoug
PostPosted: Fri Jun 15, 2007 2:05 pm     Reply with quote
When using a PIC with VPP and MCLR on the same pin, does anyone use the supervisory chips like a MAX6585 or MAX806 ? Those MAX chips only tolerate +6V on the open collector output so I suspect they would blow when VPP is applied to the MCLR pin for programming. Do I have to use jumpers or is there another family of supervisory chips I can use? Or does everyone just use a resistor to VCC?
PostPosted: Fri Jun 15, 2007 2:22 pm     Reply with quote
Microchip AN820 -- System Supervisors in ICSP Architectures
http://ww1.microchip.com/downloads/en/AppNotes/00820a.pdf
TB087 -- same topic
http://ww1.microchip.com/downloads/en/AppNotes/91087a.pdf
SherpaDoug
PostPosted: Fri Jun 15, 2007 2:48 pm     Reply with quote
Thanks, I should have checked the Microchip apnotes.
