Display value to a 7 segments display.(howto?)
jccsantos
PostPosted: Fri Jun 15, 2007 9:56 am     Reply with quote
Hi, i have this code.
{  float temperature;
  setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   printf("inicio.\r\n");
   init_max();
   Set_device();
   Power_mode(true);
   Decode_mode(0x0F);
   Scan_Limit(0x03);
   Set_intensity(0x3f);
   Input_Config(0x4f);
   test(true);
   test(false);
   Print_display(0,0,0,0);
   while(1){
  temperature = ds1820_read();
  printf("TEMP: %3.2f \r\n", temperature);
  //delay_ms(2000);
this work fine, in a terminal i have the temperature displayed.
But now my problem:
I want to display in a mx5969 the value of temperature.
I start to make this for sending to max the number for the 4 display´s.
Void print_display(int digit1, int digit2, int digit3, int digit4) {  //Display segments
   i2c_start();
   i2c_write((device<<1) & 0xFE);
   i2c_write(0x20);
   i2c_write(digit1);
   i2c_write(digit2);
   i2c_write(digit3);
   i2c_write(digit4);
   i2c_stop();
make a print_display(1,2,3,4); for example it work fine.
My question is how to pass the "temperature = ds1820_read();" for the max6959
in 2 cases:
Temperature example: 23.65ºC
1º display in max the 4 number´s 23 65
2º send to first two 7 seg´s the number 23 and to the second two seg´s another value(another sensor for example).
Thank´s in advance.
