Negative input
javi.ar
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Negative input
PostPosted: Wed Jun 13, 2007 12:55 pm     Reply with quote
Hi everyone:
One question what would I read if a digital input i aplly -5v ?
the second one would I be able to read negative values with ADC ?
Thanks a lot, sorry for the questions but I am still learning...
SherpaDoug
PostPosted: Wed Jun 13, 2007 1:40 pm     Reply with quote
If you REALLY pull the PIC pin down to -5V you will probably destroy the PIC. Fortunately the PIC pins have protection diodes to make this difficult. Read about "Input Protection" or "Protection Diodes" on the datasheet. Also read Microchip application note AN521 to see what can be done with these diodes.
To read negative voltages on an A/D pin you need to convert the voltage to positive. Often this is done cheaply by connecting two equal resistors (maybe 1K) in series from the negative signal to the A/D +5V supply. Then a -5V signal gives 0V to the A/D, a 0V signal gives +2.5V, and +5V gives +5V.
rnielsen
PostPosted: Thu Jun 14, 2007 4:24 pm     Reply with quote
Check out the electrical specifications for the part you are using. Most of them state that an input LOW can be VSS-0.3V. You can't measure a negative voltage, directly, with the ADC. If you're not sure about something, read the specification sheet first!
Ronald
