Migration from 16F870 to 16F876A?
Tagge
PostPosted: Wed Jun 13, 2007 1:33 am     Reply with quote
Hi, first, in this case its an asm code Im working with, but as "our" forum is the best at the net Wink I thought to submit it here, hope you dont mind. And maybe its some fun for you to dig in some "old" asm code?
When changing from 16F870 to 16F876A the internal ee-prom stopped working, is this some known issue? the way to read and write are the same, all adresses are the same and so on..
Heres the code that seems to be the problem?..
list    p=16f876A
include "p16f876A.inc"   ; Include file, change directory if needed
 __CONFIG 0x3F31
ORG   0x000      ; START RESET VECTOR
GOTO   MAIN
ORG   0x004
; main with some code...
; ************ INITIATION PROCESSOR *****
INIT
   BANKSEL OPTION_REG   ;SETS WHICH INTERRUPTS THAT SHOUD BE USED
   MOVLW   B'00000111'   ;SET PRESCALER TO TMR0 AND 1:256
   MOVWF   OPTION_REG
   MOVLW   B'00000000'
   MOVWF   INTCON
   MOVLW    B'00111111'
   MOVWF   TRISA      ;'0'=output, '1'= input
   MOVLW   B'00001111'
   MOVWF   TRISB
   MOVLW   B'10000001'
   MOVWF   TRISC
   MOVLW   B'00000100'   ;SET A/D TO A0,A1 AND A3 TO ANALOG INPUT WITH VDD AND VSS AS REF.
   MOVWF   ADCON1
   BANKSEL   PORTA
   MOVLW   B'01001001'   ;SET A/D CONVERTER TO FOSC/8 START WITH CHANNEL1, A/D CONVERTER ACTIVE
   MOVWF   ADCON0
   MOVLW   B'00110000'   ;SET TIMER1 TO 1:8 PRESCALER, OCSILLATOR SHUT OFF, INTERNAL CLK, TIMER OFF
   MOVWF   T1CON
   CLRF   TMR1H      ;CLEAR TIMER REGISTER
   CLRF   TMR1L      ;
   CLRF   PORTA      ;CLEAR PORTA, PORTB AND PORT C TO HAVE DEFINED START VALUES
   CLRF   PORTB
   CLRF   PORTC
   BSF   PORTC,1      ;TO GET BETTER HOLDING PERFORMANS OF ACTUATOR
   CLRF   STATE
   CLRF   ERR_TYP
   MOVLW   .10
   MOVWF   AD_CON      ;A/D VALUES HAS TO BE HIGH TEN TIMES IN A ROW BEFORE ACTUATOR IS SWITCHED OFF
   MOVLW   .15      ;NUMBER OF BLINKS BEFORE SETTING ERROR, HAS TO BE CHANGED IN STATE1, STATE5 AND STATE7 ASWELL
   MOVWF   COUNTER
   CLRF   STATE      ;SET SYSTEM TO START IN STATE 0
   CLRF   FLAGGA      ;CLEAR FLAGGREGITRET
   CLRF   TEMP
   CLRF   TEMP1
   CLRF   HTEMP1
   CLRF   HTEMP2
   MOVLW   .4      ;SET AMOUNT OF TIME FOR TMR1 TO TIME OUT BEFORE SWITCH BETWEEN SB AND PS
   MOVWF   SBPSTMR
   MOVLW   .10
   MOVWF   PEEPT
   MOVLW   .1
   MOVWF   PEEPT1
   CALL   LOADSTAT
   RETURN
;   EE-prom write and read
;*********** WRITE EEPROM *************
SAVESTAT   BSF   STATUS,RP1
      BSF   STATUS,RP0
SAVEST1   BTFSC   EECON1,WR
      GOTO   $-1
      BCF   STATUS,RP0
      MOVLW   0x01      ; EEPROM address
      MOVWF   EEADR
      MOVF   STATE, W   ; VALUE
      MOVWF   EEDATA
      BSF   STATUS, RP0
      BCF   EECON1, EEPGD
      BSF   EECON1, WREN
      MOVLW   0x55
      MOVWF   EECON2
      MOVLW   0xAA
      MOVWF   EECON2
      BSF   EECON1, WR
      BCF   EECON1, WREN
      ;GOTO   ESAVE
SAVEST2      BTFSC   EECON1,WR
      GOTO   $-1
      BCF   STATUS,RP0
      MOVLW   0x02      ; EEPROM address
      MOVWF   EEADR
      MOVF   RUN,W      ; VALUE
      MOVWF   EEDATA
      BSF   STATUS, RP0
      BCF   EECON1, EEPGD
      BSF   EECON1, WREN
      MOVLW   0x55
      MOVWF   EECON2
      MOVLW   0xAA
      MOVWF   EECON2
      BSF   EECON1, WR
      BCF   EECON1, WREN
ESAVE   BCF   STATUS, RP0
      BCF   STATUS, RP1
      RETURN
LOADSTAT   BSF   STATUS, RP1
      BCF   STATUS, RP0
      MOVWF   EEADR
      BSF   STATUS, RP0
      BCF   EECON1, EEPGD
      BSF   EECON1, RD
      BCF   STATUS, RP0
      MOVF   EEDATA, W
      BCF   STATUS, RP0
      BCF   STATUS, RP1
      MOVWF   TEMP      ; Save read value into temp
      MOVLW   .1
      SUBWF   TEMP, W
      BTFSC   STATUS, Z
      GOTO   STATOK
      MOVLW   .2
      SUBWF   TEMP, W
      BTFSC   STATUS, Z
      GOTO   STATOK
      MOVLW   .4
      SUBWF   TEMP,W
      BTFSC   STATUS, Z
      GOTO   STATOK
      MOVLW   .32
      SUBWF   TEMP, W
      BTFSC   STATUS, Z
      GOTO   STATOK
      ; NO VALID VALUE IN EEPROM
      MOVLW   .1
      MOVWF   TEMP
STATOK   MOVF   TEMP, W
      MOVWF   STATE
      BSF   STATUS, RP1
      BCF   STATUS, RP0
      MOVWF   EEADR
      BSF   STATUS, RP0
      BCF   EECON1, EEPGD
      BSF   EECON1, RD
      BCF   STATUS, RP0
      MOVF   EEDATA, W
      BCF   STATUS, RP0
      BCF   STATUS, RP1
      MOVWF   RUN
      RETURN
