CCS PCH ver 4.038 on and MPLAB
dave the blade
PostPosted: Tue Jun 12, 2007 6:41 am     Reply with quote
Hi Folks,
Has anyone else had problems with PCH from V4.048 onwards with MPLAB, when using MPLAB sim with a simple program it won't let me set breakpoints in the main C file, when i step through the code with MPSIM the dissasembly list file keeps popping up instead of seeing it step through on the main C file. I have tried with MPLAB 7.60 and a previous version 7.52, now both work with PCH V4.038.
Any ideas.
main()
int8 i,j=0;
   for(i=0;i<8;i++)
     J++;
I used the above as a simple test program in MPSIM.
Regards
Dave
PostPosted: Tue Jun 12, 2007 11:49 am     Reply with quote
I can confirm that it fails. I made a test program from your posted code
and put a breakpoint on the delay_cycles(1) line. With PCH vs. 4.040
and vs. 4.041, it gets the "unresolved breakpoint" error. I tested it with
MPLAB vs. 7.20. Earlier versions of PCH work OK (vs. 3.249, 3.039, etc).
I think it's a bug. I think CCS has done something to the COFF file,
probably. Report it to CCS tech support. When they fix it, they will
let you download the fixed version if your maintenance has run out.
In the meantime, as a work-around you could select "Expanded
COD format" in the project options window. It seems to break OK
with that one. I don't know what other limitations there may be
with that format.
#include <18F452.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
int8 i, j=0;
   for(i=0; i < 8; i++)
       j++;
       delay_cycles(1);
dave the blade
Thanks PCM
PostPosted: Wed Jun 13, 2007 3:22 am     Reply with quote
Have just reported PCM, thanks for confirming my suspicions.
Regards
Dave
