EXT_INT on 16F88 doesn’t seem to trigger the ISR
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Fri Jun 08, 2007 10:36 am     Reply with quote
Colleagues,
External interrupt refuses to trigger the INT_EXT ISR. I’m driving the external interrupt pin RB0 with a TTL square wave (0-5V) and monitoring a digital output that I toggle in the INT_EXT ISR. Here’s my rudimentary code:
#include "light_source.h"
#define  PROXIMITY   PIN_A7  // digital output to the main controller
#define  BLUE_LED    PIN_B1
// Analog channels
#define  PROX0       0
#define  PROX1       1
#define  PROX2       2
#define  PROX_THRESHOLD 0xA0  // 8-bit A/D readings will be compared to this
#INT_EXT
void EXT_isr( void )
// PURPOSE: All of the proximity detection functionality is done in this ISR.
// NOTE:    The ISR is a bit lengthy, however PIC isn't doing anything else, when this ISR has to run.
   output_toggle(PROXIMITY);   // <debug/>
#INT_RDA
void comm_isr( void )
   setup_adc_ports(sAN0 | sAN1 | sAN2 | VSS_VDD);
   setup_spi(FALSE);
   setup_timer_0(RTCC_INTERNAL | RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED, 0, 1);
   setup_vref(VREF_LOW | -2);
   ext_int_edge(H_TO_L);
   enable_interrupts(INT_EXT);
   setup_oscillator(OSC_8MHZ | OSC_INTRC);
   while (1)
      output_toggle(BLUE_LED);
#include <16F88.h>
#device ICD=TRUE
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES INTRC                    //Internal RC Osc
#FUSES NOPUT                    //No Power Up Timer
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD                    //No EE protection
#FUSES NOWRT                    //Program memory not write protected
#FUSES DEBUG                    //Debug mode for use with ICD
#FUSES NOPROTECT                //Code not protected from reading
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#use delay(clock=8000000)
#use rs232(baud=9600,parity=N,xmit=PIN_B5,rcv=PIN_B2,bits=8,stream=rs232)
Hardware: 18F88 in 28-pin QFN, Vcc = +5V, internal RC 8MHz
CCS: 3.240
I’ve checked the wiring – looks like it’s done correctly. External interrupt was working for me in the past on the 18F PICs. What could be a problem in the present case?
Thanks,
Nick
Read the label, before opening a can of worms.
PostPosted: Fri Jun 08, 2007 10:52 am     Reply with quote
#FUSES INTRC
Pin A7 is normally used by an external crystal. To configure pin A7
for digital i/o, you must use the INTRC_IO fuse.
kender
PostPosted: Fri Jun 08, 2007 11:09 am     Reply with quote
Changed INTRC to INTRC_IO, but RA7 still does not get toggled, it stays high.
The same line
works just fine in the main loop.
PostPosted: Fri Jun 08, 2007 12:15 pm     Reply with quote
I installed PCM vs. 3.240 and I was able to make it work on a
PicDem2-Plus board. I added a 330 ohm series resistor and an LED
to ground on Pin A7. When I press the button on Pin B0, the LED on
pin A7 toggles. I just change the fuse to INTRC_IO and commented
out the two debugger lines. I ran it in stand-alone mode.
I'm using MPLAB as the IDE and ICD2 as the programmer.
#include <16F88.h>
//#device ICD=TRUE   // *** COMMENTED OUT ***
#device adc=8
#FUSES NOWDT
#FUSES INTRC_IO   // *** CHANGED ***
#FUSES NOPUT
#FUSES MCLR
#FUSES BROWNOUT
#FUSES NOLVP
#FUSES NOCPD
#FUSES NOWRT
//#FUSES DEBUG       // *** COMMENTED OUT ***
#FUSES NOPROTECT
#FUSES FCMEN
#FUSES IESO
Also, this is a CCS Wizard bug and you should fix it:
kender
PostPosted: Fri Jun 08, 2007 12:41 pm     Reply with quote
PCM, I did your changes, but RA7 still doesn’t toggle from the ISR.
Still, you've pointed me in the right direction. I've tried to toggle RB3 (spare pin) for output (instead of RA7) and it worked just fine.
PostPosted: Fri Jun 08, 2007 1:53 pm     Reply with quote
What is the external circuit on pin A7 ? Check the voltage level on
the pin when it's at a high level. The problem with using the toggle
function on the 16F PICs is that it has to read the actual pin voltage.
If the load is too large, the output voltage on the pin might not be
readable as a logic high level. (The Vih voltage for pin A7 is 4.0v,
but it's only 2.0v on pin B3 -- that's almost certainly the reason).
In that's the case, it's better to keep the pin state in a static variable
and toggle that variable, and then output the state to the pin. It's then
completely independent of the external circuit. Example:
#INT_EXT
static int8 state = 0;   // Static variable
if(state)
   output_high(PROXIMITY);
   output_low(PROXIMITY);
state = !state;    // Toggle the state to 0 or 1
Note that this potential problem with the output_toggle() function doesn't
exist on the 18F PICs because they have Latch Registers. CCS toggles
the Latch Register instead of the pin register in the output_toggle()
function. It's completely internal to the PIC and isn't affected by the
external circuit on the pin.
