ADC on 16F88
oxxyfx
ADC on 16F88
PostPosted: Thu Jun 07, 2007 12:49 pm     Reply with quote
I wrote the following code to do an AD conversion of an RSSI signal. The RSSI signal should be between 0-5V range.
For testing/learning purposes, I created this code to convert the voltage from A0, divide-it by ten and beep me the value of the conversion.
Interestingly I always get 8 or 6 beeps, doesn't matter if A0 is conencted to Vdd or Vss. That means it is not doing the conversion:
Vdd is 4.8 to 5.0V.
#include <16F88.h>
#device adc=8
#FUSES INTRC                    //Internal RC Osc
#FUSES MCLR                     //Master Clear pin enabled
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#use rs232(baud=19600,parity=N,xmit=PIN_B5,rcv=PIN_B2,bits=8)
#include "tracker_16F88.h"
#use fast_io (a)
#use fast_io (b)
#Define RSSI      Pin_A0
#Define Beeper    Pin_B1
#Define On        1
#Define Off       0
int8 iX;
int8 cX;
int16 dX;
int16 adc_value;
int16 rssi_value[5];
Int16 adc_conversion(Int16 adc_value);
Int16 value;
Int8  Servo_position;
Int16 RSSI_tenth;
Void Init();
void Beep();
void Convert();
   setup_adc_ports(sAN0|VSS_VDD);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   set_adc_channel( 0 );
   set_tris_a(0b00000001);
   set_tris_b(0b00000000);
   Delay_ms(3000);
   Init();
   while(true){
   Delay_ms(5000);
   rssi_value[0] = adc_conversion(value);
   RSSI_tenth = rssi_value[0]/10;
   for (dX=0; dX<RSSI_tenth; dX++){
         Beep();
         Delay_ms(500);
Void Init(){
  for (ix=0; iX<2; iX++) {
         Beep();
         Delay_ms(150);
Void Beep() {
     for ( cX = 0; cX < 80; cX++ ) {
     Output_high(Beeper);
     delay_us ( 180 );
     Output_low(Beeper);
     delay_us ( 160 );
Int16 adc_conversion(int16 adc_value) {
int16 v[5];
int16 total;
      For(cX = 0; cX < 5; cX++) {
         delay_us(10);
         v[cX] = read_adc();
      total = 0;
      For (cX = 0; cX < 5; cX++) {
            total = total + v[cX];
      value = total/5;
      return(value);
What am I doing wrong?
Thanks, Ox.
PostPosted: Thu Jun 07, 2007 2:38 pm     Reply with quote
Your complaint is that you believe the ADC is not working.
One method to trouble-shoot this problem is to make a simple test
program that only tests the ADC.
I made the test program shown below and kept the settings the same
as in your program, such as an 8-bit ADC result and 4 MHz internal osc.
I tested it on a PicDem2-Plus board with PCM vs. 4.040. That board
is setup for a serial port on pins C6 and C7, so I jumpered over the
connections to pins B5 and B2 so it would work with a 16F88. As I
turned the trimpot on pin A0 from one side to the other, I got this
output, which is correct:
00 00 00 00 22 48 72 A1 FD FF FF FF FF
#include <16F88.h>
#device adc=8
#fuses INTRC_IO, NOWDT, PUT, BROWNOUT, NOLVP
#use rs232(baud=9600, xmit=PIN_B5, rcv=PIN_B2, ERRORS)
int8 result;
set_adc_channel(0);
   result = read_adc();
   printf("%X ", result);
kevcon
PostPosted: Thu Jun 07, 2007 3:13 pm     Reply with quote
your code won't compile with this extra brace.
   setup_spi(FALSE);
   setup_vref(FALSE);
   Delay_ms(3000);
   Init();
   while(true){
   Delay_ms(5000);
         Beep();
         Delay_ms(500);
oxxyfx
PostPosted: Thu Jun 07, 2007 4:22 pm     Reply with quote
Thank you. I stripped out the unnecessary routines from the code I posted, that's how the extra brace by mistake remained there.
I did not assume that the ADC is not working, I merely speculated over the response I've got.
If I feed the ADC with Vdd, than I should get a maximum value - I guess as a response - in case of an 8 bit = 256 or I believe this is 10 bit = 1024. Now 254 divided by 10 is 25.4, I should have heard 25 beeps - or 102 beeps...
I will try your simple program, since I do not have any debugging tools yet I have to use the beeper to count the values.
Thanks and I will report back later on the progress.
Ox.
kevcon
PostPosted: Fri Jun 08, 2007 6:58 am     Reply with quote
You might be able to send some messages out a software UART to hyperterminal as way of debugging, or if you are just trying to debug the ADC you can use the hardware UART.
oxxyfx
PostPosted: Fri Jun 08, 2007 11:03 pm     Reply with quote
Thank you, I resolved the problem. Today I received my sample shipment from Microchip containing a 16F688 - with this I built an serial LCD display and finally got around to resolve the problem.
It is much easier to troubleshoot if one can see the values of the variables. Anyway with all this, I was going nuts tonight because I thought I may be the only one the ADC is not working for... After several hours finally I decided to change ADC channels and try on a different channel - when I suddenly realized that all this time I had A0 set to analog, but I connected A1 in the test circuit.
Of course after I rewired the thing, it started working exactly as it suppose to.
Thanks for all the help.
Ox.
