Help with flashing led
rb8720
PostPosted: Mon Jun 04, 2007 1:03 pm     Reply with quote
I am using the command GPIO = (1<<4) to send a signal to the led to turn it on and GPIO = 0 to turn it off. The problem is the Annode of the led has to be connected to the pin and Cathode to ground. I need to do just the opposite and flash the led with the cathode to the pin and the annode to power. What command would i use to do this.
Thanks,
rb8720
inservi
PostPosted: Tue Jun 05, 2007 12:51 am     Reply with quote
If you use a general purpose pin then with anode to power and cathode to the pin (with resistor) , GPIO = (1<<4) will switch the led off and GPIO = 0 will switch the led on.
for sample:
  output_high(PIN_B0);  // The led is off
  output_low(PIN_B0);  // The led is on
Best regards,
dro
in médio virtus
PostPosted: Tue Jun 05, 2007 9:10 am     Reply with quote
Inservi,
Thanks for the reply. How could I apply that to more than one pin. What I need to happen is Pin 5 on, Delay, pin 5off, delay, Pin 5 on, delay, Pinn5 off, delay, Pin5 and pin2 on, delay, pin 5 and 2 off, delay,pin 3 on, delay, pin3 off, delay pin3 on, delay pin 3 off, delay, Repeat sequence.
I have the fill doagram of how it is wired. How would i display that on here ?
rb8720
PostPosted: Tue Jun 05, 2007 9:11 am     Reply with quote
BTW, I am the gues in the reply, I forgot to login.
rb8720
PostPosted: Tue Jun 05, 2007 9:28 am     Reply with quote
Here is the Diagram of how the chip is wired and what it is wired to.
http://new.photos.yahoo.com/xheavenstarx/album/576460762403708787/photo/294928804414450813/0
RB
PostPosted: Tue Jun 05, 2007 9:48 am     Reply with quote
The link isn't working.
rb8720
PostPosted: Tue Jun 05, 2007 2:00 pm     Reply with quote
Try this one, forgot to make public.
inservi
PostPosted: Wed Jun 06, 2007 1:44 am     Reply with quote
I assume that 'pin 5 on' is pin 5 high then led off.
Here is a very simple example. I added a sample to the use of the pre-processor for delay and pin 3.
#include <12F683.h>
#device adc=8
#FUSES NOWDT                   //No Watch Dog Timer
#FUSES INTRC_IO                //Internal RC Osc, no CLKOUT
#FUSES NOCPD                   //No EE protection
#FUSES NOPROTECT               //Code not protected from reading
#FUSES NOMCLR                  //Master Clear pin used for I/O
#FUSES PUT                     //Power Up Timer
#FUSES BROWNOUT                //Reset when brownout detected
#FUSES NOIESO                  //Internal External Switch Over mode disabled
#FUSES NOFCMEN                 //Fail-safe clock monitor disabled
#use delay(clock=8000000)
#define pin5On     output_high( PIN_A5 ) ;
#define pin5Off    output_low( PIN_A5 ) ;
#define pin2On     output_high( PIN_A2 ) ;
#define pin2Off    output_low( PIN_A2 ) ;
#define pin3On     output_high( PIN_A3 ) ;
#define pin3Off    output_low( PIN_A3 ) ;
#define yourDelay 1000
  setup_adc(ADC_OFF);
  setup_timer_1(T1_DISABLED);
  setup_comparator(NC_NC);
  setup_vref(FALSE);
  setup_oscillator(OSC_8MHZ);
  while(true) {
    delay_ms( yourDelay ) ;
    pin3On ;
    pin3Off ;
    pin3On ;
    pin3Off ;
If this logique is not your, you can easily change the 'output_high' by output_low'
I suppose that your diagram is not complete because so the electronic is not right.
dro.
in médio virtus
PostPosted: Tue Jul 10, 2007 12:55 pm     Reply with quote
Inservi, I think that is close to what i need but for LED_on the output has to go low. The outpunt pins are wired to the ground of an oprocoupler and must go low to activate it.
Thanks,
RB8720
inservi
PostPosted: Tue Jul 10, 2007 1:43 pm     Reply with quote
You are right. you need to change "high" by "low" and "low" by "high".
Using pre-processor is a good way to control this kind of modifications.
dro.
in médio virtus
