peachgirl Guest
a question: int16 printf |
Posted: Tue Jun 05, 2007 1:34 am |
int16 i=60000;
printf(lcd_putc, "%ld", i);
or printf(lcd_putc, "%LX",i);
I want to the result of print is 65535, But I can't |
Posted: Tue Jun 05, 2007 1:50 am |
Strange. The code as shown should work.
What result is printed?
Which compiler version are you using? |
Posted: Tue Jun 05, 2007 5:17 am |
'%ld', implies handling as a _signed_ value. You need to use '%lu' to handle values as an unsigned.
peachgirl Guest
Posted: Wed Jun 06, 2007 1:02 am |
you are right! thank you
Ttelmah wrote: | '%ld', implies handling as a _signed_ value. You need to use '%lu' to handle values as an unsigned.
