rs232 charachter receive problem
AdamkT1
PostPosted: Sat Jun 02, 2007 11:42 pm     Reply with quote
I am having troubles in receiving charachter from PC using rs232 interface.
I do not receive the charachter which I send from windows hyper terminal.
I shall appreciate any help.
#include <18F452.h>
#include <lcd.c>
#define  KEYHIT_DELAY   500     // in milliseconds
char timed_getc()
   long timeout;
   char retval;
   timeout=0;
   while(!kbhit() && (++timeout< (KEYHIT_DELAY*100)))
      delay_us(10);
   if(kbhit())
      retval = getc();
      retval = 0;
   return(retval);
   char k;
   delay_ms(200);
   lcd_init();
   while (TRUE)
      k=timed_getc();
      if (k!=0)
          lcd_putc(k);
      }//end if
}//end main
inservi
PostPosted: Sun Jun 03, 2007 12:19 am     Reply with quote
Your code look to be ok. Did you controlled the speed, data length, polarity... ?
dro
in médio virtus
AdamkT1
PostPosted: Sun Jun 03, 2007 6:50 am     Reply with quote
I have checked every thing a number of times...
No good so far.
Thanks any way.
PostPosted: Sun Jun 03, 2007 7:30 am     Reply with quote
You say 'through RS232'. How have you got this connected?. You do realise that a hardware buffer/inverter, is needed to ninterface the PIC to the PC?.
AdamkT1
PostPosted: Sun Jun 03, 2007 10:52 am     Reply with quote
I am doing it in Proteus.
AdamkT1
PostPosted: Sun Jun 03, 2007 11:06 am     Reply with quote
Can you guide me to any link for circuit diagram / schematic .
The circuit for sending charachter from PC to PIC.
Thanks for the reply.
Adam
caduhitec
PostPosted: Sun Jun 03, 2007 11:33 am     Reply with quote
hi dear,
remember that pic has only two caracters buffer, if you send more then two chars and the the pic not retrieve the chars from the buffer then comunication between PC and pic will stop. It´s a good idea use the RDA interrupt.
Cadu.
PostPosted: Sun Jun 03, 2007 11:52 am     Reply with quote
The most common IC used for this is the MAX232. It is very simple to use. Check the datasheet at www.maxim-ic.com
A nice addition to the given code would be to add the ERRORS directive in the #use RS232 line. This way you will still loose characters but at least the hardware UART will not be blocked anymore by receive buffer overflows.
This is true, but with the simple getc() implementation not working there is a more basic (hardware) related problem. Interrupts will not solve this and only make things more complicated.
rberek
PostPosted: Sun Jun 03, 2007 11:57 am     Reply with quote
You still need to put in an RS232 transceiver, like the MAX232, in Proteus. Just as Ttelmah pointed out.
r.b.
AdamkT1
PostPosted: Sun Jun 03, 2007 8:37 pm     Reply with quote
Thank you all for the suggestions.
I shall post the results, hopefully, soon.
Adam
mrpicing
PostPosted: Wed Jun 13, 2007 12:09 am     Reply with quote
set the port c direction by "set_tris_c(0x80);"
and then see the results
