TSL1406R and 18F252
tesla80
TSL1406R and 18F252
PostPosted: Thu May 31, 2007 10:23 am     Reply with quote
Hi All,
if any body know some think about this sensor please help me.
I read datasheet and wrote a routine but doesn,t work correctly
I,m appling Fclock about 4-5 MHz
but signal SO2 is coming early and I see 1 or 2 counted pixels.
This have to be 768 pixels.
Here is a routine for to count pixels;
void cp() {
   PixelCount=0;
   CK=1;SI=1;CK=0;SI=0;
   while(!SO) {
      CK=1;restart_wdt();
      CK=0;
      PixelCount++;
   printf("Pixel: %lu\n",PixelCount);
   return;
rnielsen
PostPosted: Thu May 31, 2007 11:48 am     Reply with quote
In order for a pin to be driven high you can't simply write a statement like 'CK=1'. You need to use input() or output() commands to change the state of an I/O.
Try:
void cp() {
   PixelCount=0;
   output_high(CK);
   output_high(SI);
   output_low(CK);
   output_low(SI);
   while(!SO) {
      output_high(CK);
      restart_wdt();
      output_low(CK);
      PixelCount++;
   return;
I don't know anything about this sensor so I can't say this will talk to it properly. This is the proper way to manipulate an I/O unless you are using fast_io but that's another can of worms for somebody that's not very experienced.
Ronald
tesla80
PostPosted: Thu May 31, 2007 1:47 pm     Reply with quote
#byte PORTC      = 0xF82
#byte PORTB      = 0xF81
#byte PORTA      = 0xF80
#bit   DI    = PORTA.1
#bit   SO    = PORTB.2
#bit   SI    = PORTB.1
#bit   CK    = PORTB.0
   SET_TRIS_A(0b00111111);
   SET_TRIS_B(0b00000100);  // SO pin is input
   SET_TRIS_C(0b10000000);   // RX pin is input
   PORTA = 0;
   PORTB = 0;
   PORTC = 0;
rnielsen
PostPosted: Thu May 31, 2007 4:42 pm     Reply with quote
You must also add the following if you want to use the set_tris option:
#use fast_io(a)
#use fast_io(b)
#use fast_io(c)
Ronald
tesla80
PostPosted: Sat Jun 02, 2007 3:54 pm     Reply with quote
ok, but it still doesn't work.
merakliev
PostPosted: Mon Jun 04, 2007 11:41 am     Reply with quote
a solution?
