ADC in a for cycle
oxxyfx
ADC in a for cycle
PostPosted: Tue May 29, 2007 8:58 pm     Reply with quote
I want to do 5 ADC readings one after the other and then calculate an avarage of the 5 readings.
I am not sure if I have to initialize the ADC every time inside of the loop, or outside?
Example 1:
   int8 v[5];
   int cX;
      For(cX = 0; cX < 3; cX++) {
         setup_adc_ports(AN2);
         set_adc_channel( 2 );
         delay_us(30);
         v[cX] = read_adc();
or example 2?
   int8 v[5];
   int cX;
         delay_us(30);
         v[cX] = read_adc();
I am not sure whichone should be used. Example 2 makes sense to initialize the ADC port and channel outside of the loop, but then how does the ADC know that it has to start the conversion so I can read it's value?
Thanks.
inservi
PostPosted: Wed May 30, 2007 12:38 am     Reply with quote
Did you try each version ?
I think that in this example, you make only 4 loop:
Try with "cX < 4" for 5 loops.
find 'set_adc' in the help. you will see there is a sample file 'ex_admm.c'
then try it !
dro
in médio virtus
jfk1965
PostPosted: Wed May 30, 2007 1:08 am     Reply with quote
Example 2 is the way to go.
The read adc command initialises the conversion.
JFK
oxxyfx
PostPosted: Wed May 30, 2007 6:35 am     Reply with quote
Dro, thanks, I mistyped the loops when I cut then out and pasted them here. I didn't try any of this yet, I am still waiting form a new shipment of PIC's to arrive - hopefully today.
Jfk, Thank you, in case of the second example, should I put the delay after the v[cX] = read_adc(); to give some time for the conversion to complete?
Thx.
jfk1965
PostPosted: Wed May 30, 2007 8:22 am     Reply with quote
Thx.
The delay is fine where it is as it stills gives a delay until the conversion starts.
JFK
