Decimal to digit ???
mindstorm88
PostPosted: Wed May 30, 2007 5:13 am     Reply with quote
Hi guys ,
is there an easy one to separate digit ?? let say i have
Z=6234 (base10) ,
i would like to have it as
digit1 = 6, digit2 = 2, digit3 = 3, digit4 = 4
i know it should be easy , but my brain is gone for vacation Embarassed
Pret
PostPosted: Wed May 30, 2007 6:12 am     Reply with quote
You can use itoa... or sprintf(str, "%lu", val)
Or you cand create you own code.... using %10 and /10 repeatedly... then after reverse the result. I recomand sprintf.
mindstorm88
PostPosted: Wed May 30, 2007 7:14 am     Reply with quote
Anybody sees something wrong in it ???
int digit[4] = {0,0,0,0};
count=6384;
digit[0]=count/1000;                                          // 1000
digit[1]=( count - ( digit[0] * 1000 ) ) / 100;                        // 100
digit[2]=( count - ( ( digit[0] * 1000 ) + ( digit[1] * 100 )))/10;            // 10
digit[3]=count - (( digit[0] * 1000 ) + ( digit[1] * 100 ) + (digit[2] * 10));   // 1
digit[0] and [1] are ok but [2] and [3] are bad !! i get
6
3
34
0
version 4.023
inservi
PostPosted: Wed May 30, 2007 10:15 am     Reply with quote
It's a castup probleme.
  digit[1]=( count - ( (long)digit[0] * 1000 ) ) / 100;                        // 100
  digit[2]=( count - ( ( (long)digit[0] * 1000 ) + ( (long)digit[1] * 100 )))/10;            // 10
  digit[3]=count - (( (long)digit[0] * 1000 ) + ( (long)digit[1] * 100 ) + ( (long)digit[2] * 10));   // 1
So it work.
dro.
in médio virtus
mindstorm88
PostPosted: Wed May 30, 2007 10:28 am     Reply with quote
Smile Thanks that was it !! , totally forgot that "long" was needed for the calculation!!
roykyn
hi
PostPosted: Wed Jun 13, 2007 1:42 pm     Reply with quote
i have an idea...use a for loop it will decrease the code memory a lot like this...but this method too consumes a lot of memory according to me...
i am trying to find shorter and faster code.......i also found out it consumes less memory by transferring it to j(int) and then to digit[i]. hope this will help you
int i,j;
long A,e;
A=6384;
for(i=0;i<4;i++)
         e = A / 10;
         j= A-(10*e);
                        digit[i]=j;
         A=e;
Laughing Laughing Laughing Laughing Laughing Laughing Laughing
Pret
PostPosted: Thu Jun 14, 2007 1:42 am     Reply with quote
Take my advice again. This is the basic algorithm for converting int to string.
int8 i=0; int16 n;
while(n)
  digit[i] = n % 10;
  n = n / 10;
  i++;
then reverse it if you need to.
or:
 sprintf(digit, "%lu", n);
mindstorm88
PostPosted: Thu Jun 14, 2007 6:34 am     Reply with quote
Thanks Pret , your basic algoritm :
int8 i=0; int16 n;
while(n)
  digit[i] = n % 10;
  n = n / 10;
  i++;
is saving me 125 ROMs spaces compare to mine
Someday i'll be a good coder too , working on it !!!!! Very Happy
