BOB_SANTANA
Joined: 16 Oct 2006 Posts: 110 Location: HOVE, EAST SUSSEX
Anyone Used Siemens TC35I GSM Module? |
Posted: Fri May 25, 2007 9:01 am |
Hi All
Sorry to be a pain but just want to know if anyone has sucessfull used this gsm module.
Finding it hard to get the connector , sim holder etc
http://www.mcs-nl.com/Siemens%20TC35i%20engine/126/ _________________ BOB_Santana |
mcafzap
Joined: 07 Sep 2003 Posts: 46 Location: Manchester, UK
Posted: Wed May 30, 2007 1:43 am |
Don't know if this will help you, as I've not used the TC35i, but we did use its forerunner, the TC35.
We had difficulty obtaining the flexible connector so we had some very thin pcbs made which fitted into the connector although the clamp would not then close properly. (I've ahd a quick scrabble around but can't find one, but it was maybe 0.5mm thick) This had the minor advantage that where multiple contacts are used on the power connections, the pcb had a single wide strip and the other end could be laid out so as not to need an identical connector - we used an identical one to that on the TC35 because of course, we expected to use the proper thing.
The only bother we had was making sure the module was adequately decoupled, but you probably know that already.
Steve |
BOB_SANTANA
Posted: Wed May 30, 2007 4:23 am |
Thanks for you reply
Because i am not getting anywhere with both seimens i havedecided to dump the idea and just use a mobile phone instead .
The only difference is that i would not be able to power down the unit via remote.
I found an interesting site about this if anyone is interested
Regards
Bob _________________ BOB_Santana |
