lmercor Guest
18f4550 and em4095 problem. |
Posted: Mon May 21, 2007 12:35 am |
hello, I'm doing a RFID reader with a 18f4550 and an EM4095 IC's.
I have done the reader with the pic16f877a an it works perfect, I add an LCD to see the tg number and it works. but the problem is that now I want to use the PIC18F4550 but it doesn't work and I dont know why, at first I thought that the problem were the fuses so I jus made a program to test the LCD but works fine, and then I put my program into the PIC4550 and I can't make it work, I dont know why, but I can'a saw anything in the lcd.
I really don't know what my problem is, as I said before, I thought it were the fuses but with a test program i realize it weren't. byt the way rigth now I'm not using the USB I tried with a 4MHz and 20Mhz cristal and I get the same response... nothing.
please a little help with this.
Thanks |
lmercor Guest
this is part of my code. |
Posted: Mon May 21, 2007 3:40 pm |
#include <18F4550.h>
#fuses HS, NOWDT, PUT, BROWNOUT, NOLVP
#define use_portd_lcd TRUE
#define LCD_DATA_PORT portd
#define LCD_TYPE 2
#define LCD_TRIS_LOCATION trisd
#include <lcd.c>
#include <em4095.c>
#include <em4102.c>
void main(void) {
int8 code[5];
int32 tagNum;
int8 customerCode;
int8 i, j;
int8 dato_org;
rf_init();
rf_powerUp();
while(TRUE) {
if(read_4102(code)) //read the code
for (i=0; i<5; i++) {
dato_org = code[i];
code[i] = 0;
for (j=0; j<8>>(j)) & 0x01);
if(j<=6) {
code[i] <<= 1;
tagNum = make32(code[1],code[2],code[3],code[4]);
customerCode = code[0];
printf(lcd_putc,"\fNo: %x%lx", customerCode, tagNum);
I think the problem could be with the interrups. |
Posted: Mon May 21, 2007 3:45 pm |
Quote: | for (j=0; j<8>>(j)) & 0x01); |
This is not readable code.
When you post code, please disable HTML. There's a tickbox to do this
below the posting window.
Also, please register and login (set it for "auto" login). Then you can
edit your posts when a problem like this occurs. You can also set
your user profile to always disable HTML. |
Re: 18f4550 and em4095 problem. |
Posted: Sun Oct 04, 2009 3:53 am |
lmercor wrote: | hello, I'm doing a RFID reader with a 18f4550 and an EM4095 IC's.
Thanks |
I'm very happy when i 'm readed these statement. I'm searching the rfid use 16f877a. Can you give me the principle (of the rfid reader kit) that you did? Thank a lot before. My address : ltson05bkdn@gmail.com .
We can talk together about the microcontroller . I hope I can learn more and help you as I can. |
