another noob question
baztardo
PostPosted: Sat May 19, 2007 3:47 pm     Reply with quote
whata does this mean? it is in the header file named 16f84a.h
#define PIN_A0 40
#define PIN_A1 41
and so on...
thanks
PostPosted: Sat May 19, 2007 8:48 pm     Reply with quote
In the current manual on page 157 look at the Input() command explanation about bit addresses. That should help.
baztardo
PostPosted: Sun May 20, 2007 4:54 am     Reply with quote
umm...
i dont have manual of CCS..
im just using it here in the office which is owned by my boss
Crying or Very sad
the_real_baztardo
PostPosted: Sun May 20, 2007 5:39 am     Reply with quote
Ask your Boss.
baztardo
PostPosted: Sun May 20, 2007 7:00 am     Reply with quote
ok thanks
and btw..what does carriage return means?
thanks
baztardo- Ver 2.0
RE:
PostPosted: Sun May 20, 2007 7:50 am     Reply with quote
it means Ascii 13
PostPosted: Sun May 20, 2007 8:23 am     Reply with quote
The CCS manual is on the CCS DownLoad page:
http://www.ccsinfo.com/downloads.php
BTW, although we don't mind answering a few basic questions here and there, this board is not intended for "teach myself C by asking a lot of questions". You need to do some work on your own and also use Google to get the answers to the basics and learn C.
http://www.cs.cf.ac.uk/Dave/C/
http://cslibrary.stanford.edu/101/EssentialC.pdf
http://www.cprogramming.com/tutorial.html
You definitely need a copy of Kernighan and Ritchie (C Programming Language, 2nd Edition).
There are a number of C Language newsgroups also available.
Good Luck!
baztardo
PostPosted: Sun May 20, 2007 5:05 pm     Reply with quote
ok... Rolling Eyes
thanks for the replies
