CCS CDC (Virtual RS232) Ex printf not working
dish_moose
PostPosted: Thu May 17, 2007 8:22 am     Reply with quote
I am trying to get the CCS CDC (Virtual RS232) Example to work. I have the PIC18F4550 USB development board connected to a usb port hyperterminal com3, and the serial port connected to hyperterminal com1. I can type in either hyperterm window and have the characters go from serial to usb & vice versa.
    #DEFINE LED1  PIN_A5
 #include <18F4550.h>
 #fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
 #use delay(clock=48000000)
//#else //use the National USBN960x peripheral
// #DEFINE LED1  PIN_B3
// #include <18F452.h>
// #fuses HS,NOWDT,NOPROTECT,NOLVP
// #use delay(clock=20000000)
//#endif   //endif check to see which peripheral to use
// If you are using a USB connection sense pin, define it here.  If you are
// not using connection sense, comment out this line.  Without connection
// sense you will not know if the device gets disconnected.
//       (connection sense should look like this:
//                             100k
//            VBUS-----+----/\/\/\/\/\----- (I/O PIN ON PIC)
//                     +----/\/\/\/\/\-----GND
//                             100k
//        (where VBUS is pin1 of the USB connector)
//#define USB_CON_SENSE_PIN PIN_B2
#include <usb_cdc.h>
// Configure the demonstration I/O
#define LED2 PIN_B4
#define LED3 PIN_B5
#DEFINE BUTTON PIN_A4
#define LED_ON output_low
#define LED_OFF output_high
// usb_debug_task()
// When called periodically, displays debugging information over serial
// to display enumeration and connection states.  Also lights LED1 based upon
// enumeration and status.
void usb_debug_task(void) {
   static int8 last_connected;
   static int8 last_enumerated;
   int8 new_connected;
   int8 new_enumerated;
   static int8 last_cdc;
   int8 new_cdc;
   new_connected=usb_attached();
   new_enumerated=usb_enumerated();
   new_cdc=usb_cdc_connected();
   if (new_enumerated)
      LED_ON(LED1);
      LED_OFF(LED1);
   if (new_cdc)
      LED_ON(LED2);
      LED_OFF(LED2);
   if (usb_cdc_carrier.dte_present)
      LED_ON(LED3);
      LED_OFF(LED3);
   if (new_connected && !last_connected)
      printf("USB connected, waiting for enumaration...\r\n\n");        //none of this is output to hyperterminal
   if (!new_connected && last_connected)
      printf("USB disconnected, waiting for connection...\r\n\n");
   if (new_enumerated && !last_enumerated)
      printf("USB enumerated by PC/HOST\r\n\n");
   if (!new_enumerated && last_enumerated)
      printf("USB unenumerated by PC/HOST, waiting for enumeration...\r\n\n");
   if (new_cdc && !last_cdc) {
      printf("Serial program initiated on USB<->UART COM Port\r\n\n");
      printf(usb_cdc_putc, "\r\n\nCCS CDC (Virtual RS232) Example\r\n\n");
   last_connected=new_connected;
   last_enumerated=new_enumerated;
   last_cdc=new_cdc;
void main(void) {
   char c;
   LED_OFF(LED1);
   LED_OFF(LED2);
   LED_OFF(LED3);
   printf("\r\n\nCCS CDC (Virtual RS232) Example\r\n");
  #ifdef __PCH__
   printf("PCH: v");
   printf(__PCH__);
  #else
   printf("PCM: v");
   printf(__PCM__);
  #endif
   printf("\r\n");
   usb_init();
  #if !(__USB_PIC_PERIF__)
   printf("USBN: 0x%X", usbn_get_version());
   printf("\r\n\n");
  #endif
   while (TRUE) {
      usb_task();
      usb_debug_task();
      if (kbhit()) {
         c=getc();
         if (c=='\n') {usb_cdc_putc('\r'); usb_cdc_putc('\n');}
         if (c=='\r') {usb_cdc_putc('\r'); usb_cdc_putc('\n');}
         if (c=='%') {printf("\r\n\nRS232 TEST\r\n\n");
         putc('\r');
         putc('X');
         else {usb_cdc_putc(c);}
      if (usb_cdc_kbhit()) {
         c=usb_cdc_getc();
         if (c=='\n') {putc('\r'); putc('\n');}
         if (c=='\r') {putc('\r'); putc('\n');}
         if (c=='$') {printf(usb_cdc_putc, "\r\n\nRESET COMMAND\r\n\n");}
         else {putc(c);}
the usb_cdc_putc printf works yet the standard printf does not work. The standard putc also works. Any sugestions??
dish_moose
PostPosted: Fri May 18, 2007 7:35 am     Reply with quote
seems I was using 4.037 - after downloading 4.038 the example program works just as it should.
