Mapping an LCD to PORTA on a 18F2520 using #byte command...?
SC
PostPosted: Thu May 17, 2007 6:46 am     Reply with quote
Is there any reason why an LCD should not be overlayed to PORT A on a 18F2520?
In the driver file LCD.C, the LCD is always mapped to either PORT B or PORT D using the #byte lcd = 0xF81 or #byte lcd = 0xF83 command which I understand. I have succesfully mapped the LCD to PORT B on a 16F648 device, but now I want to map the LCD to PORT A on a 18F2520 device using #byte lcd = 0xF80; however I cannot get it to work....Any ideas - am I missing something?
Thanks,
Spero Colyvas
PostPosted: Thu May 17, 2007 9:02 am     Reply with quote
Beware that the A4 line on many PIC's, does not have any drive 'upwards'. If used as an output, it needs a pull-up resistor added.
future
PostPosted: Thu May 17, 2007 9:17 am     Reply with quote
I map it like this
#define LCDPORT  PORTD
#define LCDTRIS  TRISD
struct lcd_pin_map
    unsigned char unused1:1;
    unsigned char rs:1;
    unsigned char rw:1;
    unsigned char en:1;
    unsigned char data:4;
lcdpin, lcdtris;
#locate lcdpin  = LCDPORT
#locate lcdtris = LCDTRIS
