Is it OK to sell source code containing CCS Drivers ?
arunb
PostPosted: Wed May 16, 2007 8:37 am     Reply with quote
I have developed several projects that use the standard CCS drivers for various devices like 24LC256, MCP3208 etc alongwith the code I developed.
Is it OK to sell source code containing the drivers for these devices ??
Also can the source code be freely distributed.
Some other clarifications...
1. Please be advised that, some buyers may not have PCM or PCH installed on their systems, or they may have the free version installed, are there any licensing issues here as well ??
2. How will the license apply for magazine readers ?? Is it OK to print source code of drivers alongwith , code developed by me ???
thanks
arunb
PostPosted: Wed May 16, 2007 9:05 am     Reply with quote
The CCS source code comes with the compiler. Since anyone wanting to compile the project, will have to have the compiler, they will have the source code allready. Look at the heading inside one of the driver modules, to see the exact terms.
rberek
PostPosted: Wed May 16, 2007 10:49 am     Reply with quote
I do not believe you can distribute CCS source code without express permission from CCS. You can't even really publish it on this site.
r.b.
arunb
RE:
PostPosted: Wed May 16, 2007 11:47 pm     Reply with quote
Well OK instead of publishing I sell my code (containing the drivers) to my customers all in a zip file .... then will this be OK ??
Instead of printing out the source code I could give a general flow diagram of the system and then sell the code (as a zip file) to people , will this be OK ??
thanks
arunb
languer
PostPosted: Thu May 17, 2007 12:05 am     Reply with quote
I do not see why would there be any doubts of how to handle this. Directly from the driver files:
//// This source code may only be used by licensed users of the CCS C ////
//// compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, reproduction ////
//// or distribution is permitted without written permission. ////
//// Derivative programs created using this software in object code ////
//// form are not restricted in any way. ////
Once you compile the code you are free to use as you wish, since at that point it is yours. But the source code is not, you are licensed to use it but distribution is very clearly stated.
arunb
RE:
PostPosted: Thu May 17, 2007 9:22 am     Reply with quote
Thank you for the reply, this clears my query ..
But options arare the options left open to me if I want to, distribute my source code containing the drivers....???,
thanks
arunb
RolandAldridge
PostPosted: Thu May 17, 2007 10:10 am     Reply with quote
I'd suggest you distribute your code by itself, and tell people that to make it work they have to compile it with the CCS compiler available at CCS - this way they will *have* to get the drivers too.
You may want to add some documentation telling the user how to modify the code to point to the right location of the drivers if he installs them somewhere non-standard.
Roland
Roland Aldridge
www.amio2.com
PostPosted: Thu May 17, 2007 10:12 am     Reply with quote
Write your own.
However, since the code can't be compiled without a CCS compiler, anyone wanting to use the sources is going to need a compiler that will include the drivers.
languer
Re: RE:
PostPosted: Thu May 17, 2007 12:50 pm     Reply with quote
I think the simplest answer is to create your own. Look at the source files, they're not complicated at all (at least 24256.C & MCP3208.C) - straight from the datasheet. You should be able to re-write this in your own way, and then you are the owner. Or you can ask CCS permission to distribute the source code.
There is a third option, but I am no advocate for it so I won't go there ([spam] might though...).
PostPosted: Fri May 18, 2007 2:13 am     Reply with quote
There is one other option possible with the newer compilers.
You could generate a library 'header', and precompile the drivers to a .o file. This way the sources are not needed for the drivers, and you can keep to the terms of the CCS agreement.
