Simple function overloading problem
tbob
PostPosted: Tue May 15, 2007 2:58 pm     Reply with quote
I'm trying to overload a very simple function I've created. I've tried using a header containing function prototypes, or not using them.
short lbatt_light(void);
short lbatt_light(short on_off);
short err_light (short on_off);
   return ~LBATT_IND;
   if (TRIS_LBATT_IND == 0)
      LBATT_IND = ~on_off;   // a logical '0' turns the light on
                           // logical '1' turns it off
      return 0;
   else return 1;   // If not configured as an output, return failure
   short light_success;
   TRIS_LBATT_IND = 0;
   if( lbatt_light() == LIGHT_OFF )
      light_success = lbatt_light(LIGHT_ON);
      light_success = lbatt_light(LIGHT_OFF);
   if(light_success)
      err_light(LIGHT_ON);
Very simple LED on/off type code. The warning I get is as follows:
>>> Warning 203 "C:\1GMO1001\main.c" Line 102(1,1): Condition always TRUE
*** Error 165 "C:\1GMO1001\main.c" Line 104(16,17): No overload function matches
*** Error 51 "C:\1GMO1001\main.c" Line 106(1,5): A numeric expression must appear here
the lbatt_light() function clearly matches my "short lbatt_light(void)" prototype, so what is the problem here?
thanks for any help! Using compiler v4.011
kevcon
PostPosted: Tue May 15, 2007 3:03 pm     Reply with quote
According the the version info page, this was fixed in 4.031
http://www.ccsinfo.com/devices.php?page=versioninfo
EDIT:
Although it looks like it doesn't work in 4.037.
