problem to display decimal point
deepakomanna
View user's profile Send private message AIM Address Yahoo Messenger
PostPosted: Sat May 12, 2007 4:32 am     Reply with quote
Dear Sir,
i am using 16f913, MPLAB 7.5 Ver. & CCS PCM C Compiler, Version 3.249, 34534.
here i want to display 0.0 digits on a glass lcd display.
initially i display 00,then i am trying to disply 0.0,
the right most digit will not displaying.displying 0. only.
here is my short code.
#include<16F913.h>
#fuses INTRC_IO,NOWDT,PUT,/*****/MCLR,PROTECT,NOCPD,NOBROWNOUT,NOPROTECT,NOIESO,NOFCMEN
#use delay(clock=8000000)
//            A   B   C   D   E   F   G   DP
//            b7   b   b5   b4   b3   b2   b1   b0
#define DIGIT1  COM3+6,   COM2+6,   COM0+6,   COM1+6,   COM0+5,   COM3+5,   COM2+5,   COM1+5      // DISPALYS 0 FROM RIGHT SIDE
#define DIGIT2  COM3+7,   COM2+7,   COM0+7,   COM1+7,   COM0+4,   COM3+4,   COM2+4         // DISPALYS 1 FROM RIGHT SIDE
#define DIGIT3  COM3+8,   COM2+8,   COM0+8,   COM1+8,   COM0+3,   COM3+3,   COM2+3               // DISPALYS FROM RIGHT SIDE
#define DIGIT4  COM3+9,   COM2+9,   COM0+9,   COM1+9,   COM0+2,   COM3+2,   COM2+2                  // DISPALYS FROM RIGHT SIDE
#define DIGIT5 COM3+11,   COM2+11,   COM0+11,   COM1+11,   COM0+1,   COM3+1,   COM2+1                  // DISPALYS FROM RIGHT SIDE
#define DIGIT6 COM3+12,   COM2+12,   COM0+12,   COM1+12,   COM0+0,   COM3+0,   COM2+0                  // DISPALYS FROM RIGHT SIDE
#define VLCD_ENABLE 0x10
#define BLANK 0
byte const Digit_Map[10] = {0xFC,0x60,0xDA,0xF2,0x66,0xB6,0xBE,0xE0,0xFE,0xF6};
int8 i;
void init_CPU();
void lcd_putc(int);
int8 lcd_pos ;
byte segments;
   int number ;
   init_CPU();
   number = 0;
   i = 0;
   lcd_pos = 1;
         lcd_putc(number);
         if(number++== 9)
                    number = 0;
void lcd_putc(int c)
          if((c>=0)&&(c <= 9))
                segments=Digit_Map[c];
          switch(lcd_pos)
                  case 1:
                        LCD_SYMBOL(segments,DIGIT1);
                        LCD_SYMBOL(0x01,DIGIT1);
                        LCD_SYMBOL(Digit_Map[i],DIGIT2);
                        if(segments == Digit_Map[9])
                              segments = Digit_Map[0];
                              i++;
                        if(i == 10 )
                                   i = 0;
                           lcd_pos = 1;
void init_CPU()
/**************  PORT SETTINGS ****************/
   PORT_B_PULLUPS(0XC0);
   SET_TRIS_A(0X80);
   SET_TRIS_B(0XC0);
   SET_TRIS_C(0X27);
   SET_TRIS_E(0X08);
   SETUP_COMPARATOR(NC_NC_NC_NC);
   SETUP_LCD( LCD_MUX14 | LCD_INTRC |VLCD_ENABLE , 2);
            segments=BLANK;
                  lcd_symbol(segments,DIGIT6);
                  lcd_symbol(segments,DIGIT5);
                  lcd_symbol(segments,DIGIT4);
                  lcd_symbol(segments,DIGIT3);
                  lcd_symbol(segments,DIGIT2);
                  lcd_symbol(segments,DIGIT1);
Thank You,
With Best Regards,
Deepak.
MarcosAmbrose
Re: problem to display decimal point
PostPosted: Sun May 13, 2007 12:56 am     Reply with quote
Well since number is an int there's not a lot to be gained by displaying as an decimal point, but if you want to display a decimal 0 you can format your output with a printf
    printf(lcd_putc,"%d.0",number);
deepakomanna wrote:
Dear Sir,
deepakomanna
PostPosted: Sun May 13, 2007 9:26 pm     Reply with quote
but sir, here i am incrementing right most digit i.e. .0 from 0-9. and the decimal point i have to blink in every sec.
Further to display the decimal point i made change in code is
byte const Digit_Map[11] = {0xFD,0x61,0xDB,0xF3,0x67,0xB7,0xBF,0xE1,0xFF,0xF7,0x00};
plz reply soon
Thank You,
With Best Regards,
Deepak.
PostPosted: Mon May 14, 2007 2:25 am     Reply with quote
First comment, the 'best' way to us an integer, is to use the %w format.
If you use:
int16 val;
val=123;
printf(lcd_putc,"%4.1w",val);
The compiler will output the integer value '123', as "12.3". You can increment/decrement the integer as you want, without problems...
Now, the reason for the large 'silence', is that your code is written in a way that makes it very hard to follow what you are doing, and how you are trying to do it. Learn to use comments, and lay things out in a logical way. Keep lcd_putc, so that it handles a single character, as in the example, ex92lcd.c. All you need 'add' to the lcd_putc function, is in the line, where it puts 'segments=blank', if the value arriving is not a digit, you simply set 'segments=', and the value neded to drive the DP. Then if you send a value to it with %w, it should work.
