What am I doing wrong? (help)
circlesod
PostPosted: Fri May 11, 2007 6:38 am     Reply with quote
As a totally new to CCS Pic-C, I dowloaded the latest demo (4.034 ?) in order to try it out. Used the wizard to create all fuses and such.
Then I just added a variable declaration and compiled it. It wouldn't go thru. I don't understand what I'm doing wrong.
I'll get get this Error everytime I compile:
**** Error 51 "main.c" Line 17(1,5): A numeric expression must appear here
1 Errors, 0 Warning.
Pointing to the row where "char text[20];" is located. If I delete this line, the error is gone.
Here is a copy of the simple code:
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_1(T1_DISABLED);
   // TODO: USER CODE!!
   char text[20];               // Testing array for strings --> (causing compile error)
kevcon
PostPosted: Fri May 11, 2007 7:31 am     Reply with quote
Your are trying to declare a variable after your code, move it to the top of your main loop.
circlesod
PostPosted: Fri May 11, 2007 12:11 pm     Reply with quote
Yes... You're totally right. Stupid me...!
Thank you! Embarassed
But this one gives me a headache:
int porta = 0b111111;
OUTPUT_A(porta);             <-- Works fine
OUTPUT_A(0b000000);          <-- Error!
Compiling this code will generate there two errors because of the line "OUTPUT_A(0b000000);":
*** Error 28 "C:\Projects\Ledseg.c" Line 11(10,11): Expecting an identifier
*** Error 43 "C:\Projects\Ledseg.c"" Line 66(12,13): Expecting a declaration
2 Errors, 0 Warnings.
Am I not allowed to put direct values in here? If I first declare a variable for value "0b111111" and then put the value in the OUTPUT_A(x), it works fine. But not with a value.... Why?
kevcon
PostPosted: Fri May 11, 2007 12:28 pm     Reply with quote
Those two lines work fine on my system.
Doble check you aren't missing a semicolon above them.
PostPosted: Fri May 11, 2007 12:36 pm     Reply with quote
This is probably what's happening:
#include <18F452.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
int8 a,b,c;
a = 0x55;
b = 0xAA;
c = a + b;
OUTPUT_A(porta);
OUTPUT_A(0b000000);
Don't put variable declarations (the line in bold) in the middle of your
code. They must go at the start of the function (or be globals).
Move the line shown in bold so it's just below the declaration for a,b,c.
circlesod
PostPosted: Fri May 11, 2007 1:10 pm     Reply with quote
I don't know. It seems that the compiler isn't consistant.
If I compile this, everything works alright:
#include <16F877.h>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD                    //No EE protection
#FUSES NOWRT                    //Program memory not write protected
#FUSES NODEBUG                  //No Debug mode for ICD
   setup_adc(ADC_OFF);
   OUTPUT_A(0b000000);          <-- Works fine
But if I compile the following, I will get the Error messages shown in the post above.
#include <16F877.h>
#device adc=8
OUTPUT_A(0b000000);       <-- Gives Error
   setup_adc(ADC_OFF);
Sometimes there is a need to alter the ports (for example) outside the main loop. It seems that the only way to do that, is to first put a value into a variable and the make the OUTPUT, which will waste both clock cycles and memory.
Anyone here that do not get errors on the 2nd code above?
(Compiled by Pcw.exe v4.034 for 16F877)
kevcon
PostPosted: Fri May 11, 2007 1:27 pm     Reply with quote
Even though the first one compiles with the statment outside of a function, it doesn't generate any code.
You cannot execute code outside of a function.
