2 serial INT_RDA and INT_EXT
soulweed
PostPosted: Wed Mar 14, 2007 12:27 pm     Reply with quote
hey guy please tell me,Why INT_EXT doesn't work
#include <18f452.h>
#include <stdlib.h>
#include <CTYPE.h>
#include <STRING.h>
#use rs232(stream=CH1,baud=9600,xmit=PIN_C6,rcv=PIN_C7)//Hw UART-->INT RDA
#use rs232(stream=CH2,baud=9600,xmit=PIN_B1,rcv=PIN_B0,FORCE_SW)//SW UART-->INT EXT
BOOLEAN RX=0;
int j,i,a,b,c;
float Ans,cTemp,mask=0.1;
float Inact_valve,act_valve;
int LEN;
int ptr,ptr2=0;
char command;
unsigned char recv1[5];
static byte Temp[16],Temp2[8];
float MASK_value;
void CHECK_Valve(float);
int convHex(char);
/************************  INT Rx Service Routine  ***************************/
#INT_RDA  //Rx PIN Connect to D.O. Meter
void hw_uart_isr (){
      fgets(Temp,CH1);
         a =convHex(Temp[12]);   //Convert Ten Digit
         b =convHex(Temp[13]);   //Convert Unit Digit
         c =convHex(Temp[14]);   //Convert .X Digit
         a =a*10;                 //multiply 10 for TEN Digit
         cTemp =c*(mask);         //Assigned floating point Ctemp value
         Ans=a+b+cTemp;
         CHECK_Valve(Ans);
         RX=1;      //Set RX for INT Service finish
         for (i=0;i>15;i++){
               Temp[i]=0; //Clear value in Temp[]
            return;
/**********************  INT EXT <Virtual> Routine  *************************/
#INT_EXT
void sw_uart_isr (){
      fgets(Temp2,CH2);
      command=Temp2[0];
      recv1[0]=temp2[1];
      recv1[1]=temp2[2];
      recv1[2]=temp2[3];
      recv1[3]=temp2[4];
      switch (command){
         case 'A' :
               MASK_value=atof(recv1);
               act_valve=MASK_value;
                fprintf(CH2,"ACTIVE Value is : %f\n\r",act_valve);
         case 'I' :
               Inact_valve=MASK_value;
               fprintf(CH2,"INACTIVE Value is : %f\n\r",Inact_valve);
         }// Close Switch
            for(i=0;i>7;i++){
               Temp2[i]=0;
            for(i=0;i>4;i++){
               recv1[i]=0;
      fprintf(CH2,"Oxygen in AIR is : %f\n\r",Ans);
                     return;
/********************************  MAIN Routine  **********************************/
void main ()
ext_int_edge(H_TO_L);
enable_interrupts(INT_EXT);
enable_interrupts(INT_RDA);
set_tris_d(0xFE);
for(;;){
      if (RX){
            RX=0;
         delay_ms(5000);
         fprintf(CH2,"GODD\n\r");
/*******************  convert Routine  ************************/
int convHex(char Data) {
      switch  (Data) {
         case '0' :
                return 0x00;
         case '1' :
                return 0x01;
         case '2' :
                 return 0x02;
         case '3' :
                 return 0x03;
         case '4' :
                return 0x04;
         case '5' :
                return 0x05;
         case '6' :
                return 0x06;
         case '7' :
                   return 0x07;
         case '8' :
                return 0x08;
         case '9' :
               return 0x09;
         default :break;
/*******************  CHECK_Valve Routine  ************************/
void CHECK_Valve(float Ans){
         if (Ans <act_valve>act_valve) & (Ans >= Inact_valve)){
            output_low(PIN_D0);
And how to set INT priority...
Thank alot
PostPosted: Wed Mar 14, 2007 12:49 pm     Reply with quote
for(i=0;i>7;i++){
Temp2[i]=0;
for(i=0;i>4;i++){
recv1[i]=0;
The loops above will never execute, because the test is wrong.
It should be "less than", not "greater than".
Also, if you want to clear the 'Temp2' array, your loop count is wrong.
It should be 8. The following loop will go through indexes 0 to 7,
which is a total of 8. Temp2 has 8 elements.
for(i=0; i < 8; i++)
     Temp2[i]=0;
A better way to do it is like this:
for(i=0; i < sizeof(Temp2); i++)
     Temp2[i]=0;
This way, the compiler calculates the size of the array. You don't
have to enter a number. If you change the array size later, the
compiler will automatically change the loop count to match the new size.
These things may not have anything to do with your #int_ext problem,
but that's what I saw immediately. There might be other problems.
G-TECHNIC
PostPosted: Fri May 11, 2007 7:45 am     Reply with quote
Only a little comment. Your HexConv routine ...it was the same effect to substact 48 from the ascii value
'0' -> 48 or 30Hex
so '0' - 48 = 0 !!
return (Data-48)
Best regards
PostPosted: Fri May 11, 2007 10:08 am     Reply with quote
Also, as soon as _one_ serial character is received, it'll sit in the RDA interrupt, till an entire string is received, and while this is happening, not be able to respond to int_ext. Similarly, if it does get to int_ext, it'll stay in the int_ext, and not respond to the RDA interrupts.
Don't use 'gets' inside interrupts. Get one character only, and attach this to a 'string' yourself.
