Best method to interpolate a point on a curve?
control guy
PostPosted: Wed May 09, 2007 8:58 am     Reply with quote
Hi guys,
Just wondering what is the most memory efficient method to calculate a point on a curve.
I have some data like:
X Y
-50 343000
-20 48910
0 16370
20 6250
50 1802
100 341
So given say, -10 I want to find a number between 16370 and 48910.
Is there a way to do it without needing to compute the gradient and intercept or is that the only/best way for an 8 bit micro?
Regards,
Ad
future
PostPosted: Wed May 09, 2007 9:09 am     Reply with quote
Take a look at
http://www.bytecraft.com/Non-linear_Data_Transformations
sjbaxter
PostPosted: Wed May 09, 2007 11:50 am     Reply with quote
have a look at this thread:
Calibration Tables
this suggests a few methods.
Interpolation is quick but not accurate, a polynomial curve fit is more accurate but a bit slower !! I prefer the latter, but then again, my background is Instrumenatation and Test so I like the accuracy.
Regards,
Simon.
languer
PostPosted: Wed May 09, 2007 6:05 pm     Reply with quote
This is also a good link for interpolation with tables.
Reading word data from a table, interpolation
control guy
PostPosted: Thu May 10, 2007 3:16 am     Reply with quote
Thanks for the ideas ppl, much appreciated.
I've used excel to plot my dataset and solved using a polynomial.
The best fit curve I get is a 5th order poly. I currently use a straight line equation which is rough and ready and there is a significant difference in accuracy. This is what I would like to use:
y = -0.975x5 + 12.889x4 - 64.924x3 + 155.06x2 - 195.23x + 150.38
(y = temp, x = volts(0-5v))
The question is, how difficult is this to do for an 8 bit micro, and what considerations should I be aware of?
I still see the benefits of using the lookup table approach as I can specify the exact data in the code. So I think it is dependent on how practical it is to use the poly method which determines if I implement it.
BR,
Ad
sjbaxter
PostPosted: Thu May 10, 2007 5:00 am     Reply with quote
Which micro did you have in mind ? I've used the polynomial code (in the link above) in many 16Fxx and 18Fxxx devices with excellent results.
It all depends on you application and how much execution time and code space you can afford.
If its time, try the code I posted and do some timings on your micro. for your order of fit and a 40Mhz clock, the conversion should take around 620uS (according to CCS supplied figures).
Now, depending on what your calibration represents (i.e. temperature, pressure, voltage, etc) you can afford longer calc times as the sensor response time is going to be the 'slowest' part of the 'real world' to 'micro' conversion process.
Regards,
Simon.
control guy
PostPosted: Mon May 14, 2007 2:06 am     Reply with quote
Hi sjbaxter,
Thanks, I've decided to use a 3rd order poly to trade off accuracy and memory usage.
It seems to do the job!
Regards,
Ad
