michellelicious
To PCM programmer |
Posted: Tue May 08, 2007 8:45 pm |
PCM programmer wrote: | Try a simple program below, that echoes back the characters that
you type in to the terminal window. It should work.
#include <16F876A.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
char c;
c = getc();
putc(c);
This does not work for me!!! But why? The code is simple. I can only receive FROM PIC but the pic itself is not getc()ing anything.
CCS 4.013
PIC16f877 and 16f877a
Max232
Hyperterminal and Serial Port monitor
Thanx for any response |
Posted: Tue May 08, 2007 9:40 pm |
I don't have 4.013, but I do have 4.014. I tested it just now with that
verison, with a 16F877 and a PicDem2-Plus board. It works. It probably
also works with 4.013, because this type of simple program is likely what
CCS used to do some sort of pass-fail test on the version.
If you built your own board, then buy a pre-made board from some company. If you're using Proteus, then buy a real hardware board.
If you built your own serial cable, then buy a cable. |
