FFT_PIC
kaos
FFT_PIC
PostPosted: Sun May 06, 2007 5:18 am     Reply with quote
I have programmed a function "FFT_PIC" and I want to share the code to know if is possible to improve it.
#define BYTES   4
#define PUNTOS  1<<BYTES
const unsigned int Orden[] = { 0, 8, 4, 12, 2, 10, 6, 14, 1, 9, 5, 13, 3, 11, 7, 15 } ;
const float u1d[] = { -1.000000, 0.000000, -1.000000, 0.707107, 0.000000, -0.707107, -1.000000, 0.923880, 0.707107, 0.382683, 0.000000, -0.382683, -0.707107, -0.923880, -1.000000 } ;
const float u2d[] = { 0.000000, -1.000000, 0.000000, -0.707107, -1.000000, -0.707107, 0.000000, -0.382683, -0.707107, -0.923880, -1.000000, -0.923880, -0.707107, -0.382683, -0.000000 } ;
void FFT_PIC(float *x,float *y)
    int l,l1,i,l2,i1,j,cont;
   float u1,u2,t1,t2,temp;
    l2 = 1;
   cont = 0;
    for(l=0;l<BYTES;l++)
        l1 = l2;
        l2 <<= 1;
        u1 = 1.0;
        u2 = 0.0;
        for(j=0;j<l1;j++)
            for(i=j;i<PUNTOS;i+=l2)
                i1 = i + l1;
            temp = x[Orden[i1]];
                t1   = (u1 * temp);
            temp = y[ Orden[i1] ];
            temp = (u2 * temp);
            t1   = t1 - temp;
                t2   = (u1 * temp);
            temp = x[ Orden[i1] ];
            temp = (u2 * temp);
                t2   = t2 + temp;
            temp = x[ Orden[i] ];
            temp = temp - t1;
                x[Orden[i1]] = temp;
            temp = y[ Orden[i] ];
            temp = temp - t2;
                y[Orden[i1]] = temp;
                x[Orden[i]] += t1;
                y[Orden[i]] += t2;
            cont++;
            u1 = u1d[cont];
            u2 = u2d[cont];
    for(i=0;i<PUNTOS;i++)
        x[i] /= PUNTOS;
        y[i] /= PUNTOS;
Douglas Kennedy
PostPosted: Sun May 06, 2007 10:26 am     Reply with quote
The issue probably will always be with the use of floats. The PIC is very capable when you avoid floating point. Floating point is a snail and at the end of the day whether the snail has racing stripes or not it will still have a snail's pace. Before there were computing machines human calculation was very very slow. Many algorithms based on finite differences (Ex Breshenham) were employed to gain speed. Finite differences use add and subtract with an occasional divide by 2 or multiply by 2. They are used today for fast graphic processing. There is an advantage to having a snail race a shorter distance ( reducing the number of float operations) but on a PIC float will still be a snail absent floating point hardware.
