ADXL210 and ADXL202 accelerometer
Kova
PostPosted: Sun May 06, 2007 5:13 am     Reply with quote
Hi all,
sorry for my english Smile
I have seen that in the drivers directory of CCS there is an example of ADXL210 accelerometer.
I want to know if I can use this code with the ADXL202 accelerometer!
Somebody can help me?
I must make some correction to the code?
The only difference is the calculation of the A(g)??:
Adxl202 A(g) = (T1/T2 – 0.5)/12.5%
Adxl210 A(g) = (T1/T2 – 0.5)/4%
Question Question
Thanks a lot!
Bye
Kova
PostPosted: Mon May 07, 2007 1:41 am     Reply with quote
please boys...help me Bummed Out
PostPosted: Mon May 07, 2007 2:09 am     Reply with quote
How about doing a web search with http://www.google.com ?
Just by typing in a search string like: ADXL202 output_low
I was able to find drivers for CCS in less than a minute.
http://www.daimi.au.dk/~ups/PvC/final-projects/09/implementation/c-code/Devices/
http://www.mis.informatik.tu-darmstadt.de/People/kristof/notes/porcupine1/porc.c
Also use this search string: ADXL202 "#use delay"
There are many more CCS example drivers out there. Learn to use
Google. You do it by typing in the name of the chip, and then some
keyword commonly used in CCS such as "output_low" or "#use delay".
Kova
PostPosted: Mon May 07, 2007 8:48 am     Reply with quote
PCM programmer wrote:
CUT
Thanks for the links PCM programmer Razz but I wanted to know if the code included with the compiler (ADXL210.C) worked with the ADXL202 accelerometer.
Thanks for the help Cool
Bye
