PWM 16F685 Problem
geshsoft
PWM 16F685 Problem
PostPosted: Fri May 04, 2007 7:08 pm     Reply with quote
I was trying the PWM module of the PIC16F685 but so far I have no success. The code I used is:
#include "C:\Program Files\PICC\Projects\DCMControl\main.h"
setup_adc(ADC_OFF);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_1,79,1);
setup_ccp1(CCP_PWM);
setup_ccp1(CCP_PWM_L_L);
setup_ccp1(CCP_PWM_FULL_BRIDGE);
setup_ccp1(CCP_SHUTDOWN_AC_H);
set_pwm1_duty(160);
setup_comparator(NC_NC_NC_NC);// This device COMP currently not supported by the PICWizard
setup_oscillator(OSC_8MHZ);
// TODO: USER CODE!!
I was expecting to see 25kHz square wave with 50% duty cycle, but so far I see no output at all. I wonder if I did something wrong or there is a bug of some sort? Confused
PostPosted: Fri May 04, 2007 8:13 pm     Reply with quote
Try the code shown in this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=29565&start=1
If it doesn't work, post your compiler version.
geshsoft
PostPosted: Fri May 04, 2007 10:08 pm     Reply with quote
Do you mean to try compiling it the way it is there as for PIC18F4550 or to modify it to match PIC16F685? For once 16F685 has only CCP1 so it will not work in its original form.
PostPosted: Fri May 04, 2007 10:22 pm     Reply with quote
Yes, skip the 2nd CCP. Just try to make it work in Full Bridge mode.
geshsoft
PostPosted: Fri May 04, 2007 10:32 pm     Reply with quote
Here we go:
#fuses XT,NOWDT,BROWNOUT,PUT
#use delay (clock=4000000)
// Setup the ECCP for PWM in full bridge mode.
setup_ccp1(CCP_PWM_FULL_BRIDGE | CCP_PWM_H_H);
setup_timer_2(T2_DIV_BY_1, 255, 1);
set_pwm1_duty(100);
// Setup CCP2 for PWM output on pin C1.
set_pwm1_duty(50);
// Switch the H-Bridge outputs between forward
// and reverse every 5 seconds.
   // Run forward for 5 seconds.
   delay_ms(5000);
   // Run in reverse for 5 seconds.
   setup_ccp1(CCP_PWM_FULL_BRIDGE_REV  | CCP_PWM_H_H);
   delay_ms(5000);
It did not work at all. Compiler version as seen in LST file is:
CCS PCM C Compiler, Version 4.033
PostPosted: Fri May 04, 2007 10:42 pm     Reply with quote
The CCP2 stuff must be deleted, not turned into CCP1.
Make the changes shown in bold below.
#include <16F685.h> // Add this line
set_pwm1_duty(100);
// Delete the lines shown in bold below.
set_pwm1_duty(50);
delay_ms(5000);
delay_ms(5000);
geshsoft
PostPosted: Fri May 04, 2007 10:58 pm     Reply with quote
Ok, I compiled the last code that you posted and now PIN_C5 goes on for 5s and off for 5s. No other pins are affected. There is no PWM output on any of the pins either.
PostPosted: Sat May 05, 2007 1:00 am     Reply with quote
With respect pin to C5, it's behaving correctly for the Full Bridge mode.
It's the P1A pin in that mode. According to Figure 11-6 in the 16F685
data sheet, pin C5 will be either a constant high or a constant low,
depending upon whether you're going in forward or reverse.
So pin C5 is OK.
There is a note in Section 11.5 of the data sheet (PWM Enhanced mode).
It says:
The TRIS register value for each PWM output must be configured appropriately.
However, the ASM code generated by the compiler doesn't do this.
It only sets pin C5 as a low-level output pin. It leaves the other pins
(C2, C3, C4) in the default state, which is as input pins.
Here's something you could try. Add a line of code after each
setup_ccp1() function, to manually force pins C2-C5 to be outputs.
Add the lines shown in bold below.
#include <16F685.h>
set_tris_c(0xC3); // Set pins C2-C5 as outputs
set_pwm1_duty(100);
delay_ms(5000);
delay_ms(5000);
Then compile it and program it. Then when it's running, look at pin C2
in forward mode, and pin C4 in reverse mode. You should see PWM
pulses on them.
geshsoft
PostPosted: Sat May 05, 2007 2:14 am     Reply with quote
Thanks, this worked Very Happy
Why was not the compiller setting the TRIS registers anyways? I thought that this is the advantage of the standard io... Confused
