PIC 16F677 I2C ssp isr not working...
davefromnj
PostPosted: Thu May 03, 2007 2:08 pm     Reply with quote
Hello all,
I'm using the following setup:
an 18F65J10 as the I2C master,
18F44J10 as one I2c slave (addr 0x40)
and a 16F677 as an I2c slave (addr 0x20)
The 18F65J10 & 18F44J10 are working properly with test code where the 65j10 sends out data to 0x20, then to 0x40 like so:
Master pic code:
#include "C:\temp\i2Cattempt2-logic-exp\master\main.h"
#include<stdio.h>
//#int_TIMER0
//void  TIMER0_isr(void)
/*#int_SSP
void  SSP_isr(void)
   setup_psp(PSP_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_timer_4(T4_DISABLED,0,1);
   setup_vref(FALSE);
  // enable_interrupts(INT_TIMER0);
  // enable_interrupts(INT_SSP);
   //enable_interrupts(GLOBAL);
   setup_oscillator(False);
   // TODO: USER CODE!!
   int slaveaddress1;
   int slavetestdata1;
   int slaveaddress2;
   int slavetestdata2;
   int slavetestdata3;
   slaveaddress1 = 0x40;
   slaveaddress2 = 0x20;
   slavetestdata1 = 5;
   slavetestdata2 = 7;
   slavetestdata3 = 9;
      i2c_start();
      i2c_write(slaveaddress1);
     delay_ms(10);
     i2c_write(slavetestdata1);
      i2c_stop();
   printf("\n\r I2C Comms 1 complete");
      i2c_start();
      i2c_write(slaveaddress2);
     delay_ms(10);
     i2c_write(slavetestdata2);
      i2c_stop();
   printf("\n\r I2C Comms 2 complete");
      i2c_start();
     delay_ms(10);
     i2c_write(slavetestdata3);
      i2c_stop();
    printf("\n\r I2C Comms 3 complete");
    printf("\n\r");
   printf("\n\r slave address %d", slaveaddress1);
   printf("\n\r slave data %d", slavetestdata2);
   printf("\n\r");
The working pic 44j10 slave code is here with header:
slave header:
#include <18F44J10.h>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOXINST                    //Extended set extension and Indexed Addressing mode enabled
#FUSES NOPROTECT                //Code not protected from reading
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES PRIMARY                  //Primary clock is system clock when scs=00
#FUSES RESERVED                 //Used to set the reserved FUSE bits
#use i2c(Slave,Slow,sda=PIN_C4,scl=PIN_C3,address=0x40, FORCE_HW)
Working slave code .c file:
#include "C:\temp\i2Cattempt2-logic-exp\slave-44j10-uart\main.h"
#include <stdio.h>
enum {address, data};
int mode;
int i2cdat;
#int_SSP
void  SSP_isr()
   output_bit(PIN_C0, 0);
   if (i2c_poll())
      //output_bit(PIN_C0, 0);
   //   if (mode == address)
         i2cdat = i2c_read();
         printf("\n\r isc-data == %d", i2cdat);
   //      printf("\n\r mode == %d", mode);
         printf("\n\r");
   //      mode = data;
         //1st pass, ignore address data
         //output_bit(PIN_C1, 0);
/*      else
         if (mode == data)
            printf("\n\r i2cdata == %d", i2cdat);
            printf("\n\r");
            mode = address;
            if (i2cdat == 5)
               //printf("\n\r I can't believe its not butter");
            printf("\n\r NOT ADDRESS OR DATA MODE!!!");
   setup_wdt(WDT_OFF);
   setup_vref(FALSE);
////initialize variables
   mode = address;      //init i2c mode to address, since we haven't yet received i2c data
The NON-WORKING 16F677 header:
#include <16F677.h>
#device adc=8
#FUSES XT                       //Crystal osc <= 4mhz
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES NOCPD                    //No EE protection
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#use i2c(Slave,Slow,sda=PIN_B4,scl=PIN_B6,address=0x20, FORCE_HW)
The Non-working 16F677 Slave main.c:
#include "C:\temp\i2Cattempt2-logic-exp\PSUBOARD\main.h"
#int_SSP
void  SSP_isr(void)
   int ch;
   int mode;
/* if (i2c_poll());
      ch = i2c_read();
         mode = data;   //if we've gotten this far, our address was chosen
                        //and we're ready for the next byte, which is data
         mode == address;  // the next I2C byte will be an address so be ready for it
      if (ch == 7)
   output_bit(PIN_C7, 1);     // turn on logic board.
   setup_adc(ADC_OFF);
   setup_comparator(NC_NC_NC_NC);// This device COMP currently not supported by the PICWizard
// enable_interrupts(GLOBAL);
   output_bit(PIN_C0, 1);
   output_bit(PIN_C1, 1);
   output_bit(PIN_C2, 0);
   output_bit(PIN_C5, 0);
The output bits are tied to LEDs. I can turn them on or off at will in the While loop, so the hardware is ok. The LED's are turned on by setting the output pins low (the LED cathode is tied to the pic output pin, along with series current limiting resistor to 5V.)
I cannot however get C0 to light up when I put output_bit(PIN_C0, 0); in the ssp_isr().
it's almost as though the pic is NEVER seeing the I2C data.
Note that the pullups in this I2C network are 10kohm resistors, pulled to 3.3V.
Please help me trouble shoot this PIC16F677 with I2C. It supposedly has an SSP module that supports I2C in slave mode.
PostPosted: Thu May 03, 2007 2:17 pm     Reply with quote
Post your compiler version.
davefromnj
PostPosted: Thu May 03, 2007 2:24 pm     Reply with quote
all are 4.029.
PostPosted: Thu May 03, 2007 2:32 pm     Reply with quote
in the ssp_isr().
#int_SSP
void SSP_isr(void)
int ch;
int mode;
You have an enum statement in between the #int_ssp declaration and
the actual function. As a result, the compiler will generate no code
for the isr.
davefromnj
PostPosted: Thu May 03, 2007 2:38 pm     Reply with quote
in the ssp_isr().
#int_SSP
void SSP_isr(void)
int ch;
int mode;
for the isr.
I just removed the enum and INT CH, int mode statements---still no luck...
PostPosted: Thu May 03, 2007 2:43 pm     Reply with quote
The 'int ch' and 'int mode' declarations have no effect on the generation
of the isr routine. You can leave them in place.
davefromnj
in the ssp_isr().
#int_SSP
void SSP_isr(void)
int ch;
int mode;
for the isr.
Thank you for all of your time, I'm a friggin idiot:
I remarked out both global interrupts and the SSP_Isr.
It's now working with all 3 chips.
thank you!
PostPosted: Thu May 03, 2007 2:45 pm     Reply with quote
Also, your test program for the slave, as posted, has the
enable_interrupts() statements commented out. You'll never get
an INT_SSP interrupt.
