rdburghard
Code Protection with PIC18F2525 problem |
Posted: Tue May 01, 2007 2:46 pm |
I can't seem to get the CCS compiler to set the code protection bits on the PIC18F2525. I have #FUSES CPB and #FUSES PROTECT=8 in my file. I thought those two would do the trick, but they don't seem to do anything. I don't know how to check this in the CCS program but have found the ID section in the MachX programmer that shows them to me. They are never set. I can manually set them in the MachX, but really would like the CCS compiler to program them properly.
The code is running fine, but I would like to understand the code protection fuses.
Any ideas would be appreciated.
(Note: I have also emailed CCS support just now and will update this message if they help out.). |
Posted: Tue May 01, 2007 2:57 pm |
You can see the fuse settings and the Config Word(s) at the bottom
of the .LST file, after you compile your program.
1. Post a small test program that shows the problem.
2. Post your compiler version. |
rdburghard
Code Protection with PIC18F2525 problem CURED! |
Posted: Thu May 03, 2007 4:44 pm |
Thanks for all the help. I didn't know I could see the programmed fuse settings in the .LST file. That is great. I haven't been looking at that file. I need to study the assembly code anyway to learn more about it. Gotten 'spoiled' by C.
Also, CCS support emailed me and discovered my error. I had a #device=ICD line in the file that I had forgotten about. Had it in there for testing. The code protection fuses will work if I comment out that one line.
David |
