16F689 Comparator2 turned on by itself?
sandrewww
PostPosted: Sat Apr 28, 2007 6:35 pm     Reply with quote
This is sortof in follow-up to a post I made earlier this week about my 16f689 not working with my LCD. (http://www.ccsinfo.com/forum/viewtopic.php?t=30570&start=0&postdays=0&postorder=asc&highlight=16f689)
I tracked the problem to my C4 pin not toggling...
Then I finally tracked the reason to be this: the comparator 2 had turned itself on, and was comparing two of my digital inputs.
This was a very simple program so I'm not sure why the comparator was turned on but I had to manually clear the C2OE and C2ON bits before my program worked like it's supposed to.
compiler bug?
PostPosted: Sat Apr 28, 2007 11:43 pm     Reply with quote
On a question about a possible compiler bug, you should post the
compiler version.
sandrewww
PostPosted: Sun Apr 29, 2007 9:20 pm     Reply with quote
right-click properties -> version
says 4.0.0.207
PostPosted: Sun Apr 29, 2007 9:53 pm     Reply with quote
That's not the compiler version. See this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=21811&highlight=property+box&start=9
sandrewww
PostPosted: Mon Apr 30, 2007 5:03 pm     Reply with quote
ah ok thanks..
from the .lst:
CCS PCM C Compiler, Version 4.018
PostPosted: Mon Apr 30, 2007 5:21 pm     Reply with quote
I installed PCM vs. 3.214 and got this error message upon trying to
compile a test program:
Unknown device type "PIC16F689"
You probably used the Device Editor to add this PIC to your version.
If so, it's likely that the start-up code inserted by the compiler is at
least partially incorrect.
Here's the startup code generated by vs. 4.032. You may have to
add some C code to the start of your main() to duplicate these settings
if the existing startup code is doing it incorrectly.
In your post, you said that you have already done this.
0004:  CLRF   04
0005:  BCF    03.7
0006:  MOVLW  1F
0007:  ANDWF  03,F
0008:  BSF    03.6
0009:  BCF    1F.0
000A:  BCF    1F.1
000B:  BCF    1F.2
000C:  BCF    1F.3
000D:  BCF    03.6
000E:  BCF    1F.6
000F:  MOVLW  00
0010:  BSF    03.6
0011:  MOVWF  1E      // ANSEL = 0
0012:  CLRF   19      // CM1CON0 = 0
0013:  CLRF   1A      // CM2CON0 = 0
0014:  BSF    03.5
0015:  CLRF   1E      // SRCON = 0
0016:  BCF    03.5
0017:  CLRF   1B      // CM2CON1 = 0
0018:  BCF    03.6
0019:  BCF    0D.5
sandrewww
PostPosted: Mon Apr 30, 2007 8:11 pm     Reply with quote
hey, thanks for the quick responses :-)
i made a mistake in my response with my correct version number -- you must've caught me before i fixed it..
i've got PCH and PCM, and accidentally gave my pch version first.
PCM, which should be compiling this 16F code, is version 4.018 according to the top of my .lst file.
I had to upgrade mplab to 7.5 before it allowed me to program the thing with my ICD2, but it compiles/works with no hacking on my part.
here's the beginning of my program from the .lst:
0462:  CLRF   04
0463:  BCF    03.7
0464:  MOVLW  1F
0465:  ANDWF  03,F
0466:  MOVLW  71
0467:  BSF    03.5
0468:  MOVWF  0F
0469:  BCF    03.5
046A:  BSF    03.6
046B:  BCF    1F.0
046C:  BCF    1F.1
046D:  BCF    1F.2
046E:  BCF    1F.3
046F:  BCF    03.6
0470:  BCF    1F.6
0471:  MOVLW  00
0472:  BSF    03.6
0473:  MOVWF  1E
0474:  MOVLW  07
0475:  MOVWF  19
0476:  MOVLW  FF
0477:  MOVWF  1A
0478:  BSF    03.5
0479:  CLRF   1E
047A:  BCF    03.5
047B:  CLRF   1B
047C:  BCF    03.6
047D:  BCF    0D.5
....................    short onoff = 0;
0495:  BCF    74.0
....................    char temp = 0;
0496:  CLRF   75
....................    char tmpStr[8];
....................    int8 i = 0;
0497:  CLRF   7E
....................    char c;
....................    C2ON = 0;
0498:  BSF    03.6
0499:  BCF    1A.7
....................    C2OE = 0;
049A:  BCF    1A.5
....................    setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
049B:  MOVLW  85
049C:  BCF    03.6
049D:  MOVWF  10
where i earlier defined:
.................... #bit C2ON = 0x11A.7
.................... #bit C2OE = 0x11A.5
