Send data to LCD from PIC
qali246
PostPosted: Mon Apr 30, 2007 1:39 pm     Reply with quote
I am a student having a final project based on the automotive CAN-Bus system.
For my project I planed to simulate the sensor with a potentiometer connected to a PIC18F4580. The value picked by the PIC are sent to my lcd drive by a PI16F874 via a MCP2510.
I wrote a sample code for the moment and I need some feedback concerning the errors or syntax.
//code for the PIC18F//
#include <18f4580.h>
#device ICD=TRUE
#fuses HS,NOLVP,NOWDT,
#use delay (clock=20000000)
#include<can-18F4580.c>
#define GREEN PIN_A5
#define RED PIN_B1
#define YELLOW PIN_B4
#define WRITE_REGISTER_D_ID 0X400 //Destination of the frames (LCD connect with a MCP2510)
int reading,kmH;
setup_port_A(ALL_ANALOG); //port A analog
set_adc_channel(0); //read value at the potentiometer
can_init(); //PIC initialisation
can_putd (0x100,0,0,1,TRUE,FALSE); //departure of the values
delay_ms (1000); //wait until MCP2510 wakes up
while (TRUE)
reading=read_adc();
//255 samples=>63=1.18V ; 180=3.52V; thx to the fomular:(reading*5V)/255
if (reading<63)
output_low(GREEN); //for low speed 0<kmH<50 dividing reading/1.28*
output_high(RED);
output_high(YELLOW);
else if (reading<167)
output_low(YELLOW); //for indicate average speed 50<kmh<130>180)
output_low(RED); //speed to high slow dowm!!! kmH>130*
output_high(RED);
kmH=reading/1.28; //calculate the reading A/D in Kilometer per hour
can_putd(WRITE_REGISTER_D_ID, kmH, 3, 1, TRUE, FALSE); //send value read to node D
//code for the PIC16F//
#include <16F874.h>
#include <flexlcd.c>
#include <can-mcp2515.c>
#DEFINE WRITE_REGISTER_V_ID 0x100 //NODEV
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
int32 rx_id
int rx_len, rx_stat, kmH,buffer
// The lcd_init() function should always be called once,
can_init();
buffer[3]={0x10E,0x7F,kmH};
delay_ms(8) //delay of updated data
if (can_kbhit() )
if (can_getd (rx_id, &buffer[?], 3, 1,rx_len,rxstat)
if (rx_id==WRITE_REGISTER_V_ID) //if ID==the one of nodeV
lcd_gotoxy(1,1): //write the value on the first line
printf(lcd_putc,"Velocity=buffer[2]")
jds-pic
PostPosted: Mon Apr 30, 2007 3:01 pm     Reply with quote
1) please use the "Code" tags to properly format your code.
2) please don't make us guess what the problem may be.
-- what version compiler do you have?
-- does your code compile?
-- if not, what error is shown and at what line number?
-- does your code actually run? if not, what are the symptoms?
-- does your code display anything on the LCD?
-- what did you expect it to display?
-- what does it display?
3) please add some detail regarding your hardware configuration. no one here is capable of internet-assisted remote telepathy.
jds-pic
jds-pic
Re: Send data to LCD from PIC
PostPosted: Mon Apr 30, 2007 3:06 pm     Reply with quote
ps:
qali246 wrote:
I am a student...
int reading,kmH;
what do you think the result of dividing an integer by a float and storing the result as an integer is going to be?
jds-pic
