odd behaviour 16f88 and adc
Nicolas
PostPosted: Sun Apr 29, 2007 10:10 pm     Reply with quote
Odd behaviour with a 16f88 and using the built in adc.
For testing, just reading an AN1 and putting out the value to the pc via serial port. Using the internal rc (8mhz)
When I connect VDD to AN1, the ADC returns 990-992 (varies). Not the expected 1023. VSS to AN1 does return 0 properly.
The only way I can get it to return 1023 is if i apply a voltage Higher than VDD to AN1.
I tried running at 3.3v and 5v.
The voltage is stabalized with a 0.1uf cap and a 10uf cap.
Tried 3 different PIC's, same results.
(In simulation, it does properly return 1023)
#include <16f88.h>
#fuses NOMCLR, NOBROWNOUT,INTRC_IO,NOFCMEN,NOIESO
#device adc = 10
#use delay(clock=8000000,internal)      //8mhz
#use rs232(baud=4800, xmit=PIN_B6, rcv=PIN_B7,invert)   //For testing
void main () {
   long in_adc;
   delay_ms(500); //Since using intrc+mclr is off - to allow programming
   setup_adc_ports(sAN1|VSS_VDD );
   setup_adc(ADC_CLOCK_INTERNAL );
   delay_us(10);
   set_adc_channel(1);
   delay_us(10);
   in_adc = read_adc();
   printf("%Lu",in_adc);
Any ideas ?
PostPosted: Sun Apr 29, 2007 11:03 pm     Reply with quote
Read this section of the 16F88 data sheet:
Selecting the A/D Conversion Clock
It says don't use the internal RC clock for the A/D. Instead use Fosc,
with the "Divide by 8" divisor. In other words, do this:
setup_adc(ADC_CLOCK_DIV_8);
Nicolas
PostPosted: Sun Apr 29, 2007 11:35 pm     Reply with quote
Thanks for the incredibly fast response.
Tried variouse different ADC_CLOCK's and still the same problem.
No change at all, which is somewhat strange.
Mind you that was using the Internal oscillator (8mhz).
I just tried an external OSC, and it works 100%.
Possibly the internal OSC is not tuned properly, or the ADC doesnt like running with an internal OSC.
Nicolas
PostPosted: Sun Apr 29, 2007 11:43 pm     Reply with quote
I moved the Serial lines, from B7/B6 to B4/B5
and used internal OSC.
It works 100% now.
New (works properly)
#use rs232(baud=4800, xmit=PIN_B4, rcv=PIN_B5,invert)   //For testing
Old: (doesnt work properly)
I will have to investigate if its a PIC thing, or a CCS thing.
(Could have to do with RB6/7 being analog capable)
Nicolas
PostPosted: Mon Apr 30, 2007 12:07 am     Reply with quote
So i narrowed it down to the RS232 converter i was using.
The converter was not properly controlling the RCV line on the PC and was feeding a -12v to the pic, oviously because of the MUX on the AN lines, it caused weird problems.
In my case, incorrect ADC readings.
Thanks PCM Programmer, your suggestion has also reduced my TAD to almost perfect timing, so the ADC conversion is even more accurate now.
