access violations
dave.t
access violations
PostPosted: Tue Jan 14, 2003 11:19 am     Reply with quote
Hi all
I have the ccs compiler version 2.716.
I have a run sometimes of access violations ie.
"access violation at address 004f4b8d in module 'pcw.exe'. read of address 01110000"
Anybody come across this before?
Do I just ignore them?
Any help would be appreciated.
Regards.
Dave
___________________________
Original Post ID: 10687
Sherpa Doug
Re: access violations
PostPosted: Tue Jan 14, 2003 11:41 am     Reply with quote
:=Hi all
:=I have the ccs compiler version 2.716.
:=I have a run sometimes of access violations ie.
:="access violation at address 004f4b8d in module 'pcw.exe'. read of address 01110000"
:=Anybody come across this before?
:=Do I just ignore them?
:=Any help would be appreciated.
:=Regards.
What operating system are you using. A compiler that old may have problems with Win2000 or XP. Others on the board will know more than me.
:=Dave
Original Post ID: 10689
Steve H
For what it's worth....
PostPosted: Tue Jan 14, 2003 1:36 pm     Reply with quote
For what it's worth I have run 2.6xx on Win 95, 98, NT and win2k with no problems.
Steve H.
Original Post ID: 10693
Steve H
One more thing...
PostPosted: Tue Jan 14, 2003 1:37 pm     Reply with quote
I mean just the command line compiler or DOS IDE I don't use the CCS IDE so I don't know about that.
Steve H.
Original Post ID: 10694
Dave Yeatman
PostPosted: Tue Jan 14, 2003 3:55 pm     Reply with quote
FWIW, In the few cases where I have encountered this it was a C coding error. I found it by commenting out lines until narrowed it down.
Dave
Original Post ID: 10702
kolio
PostPosted: Wed Jan 15, 2003 3:15 am     Reply with quote
You're not the only one (if this might calm you down).
I had the same troubles under Win98 and WinNT.
After updating PSW (IDE to 2.31 and PCM/PCH to 2.731) the things went better - the nice message box appears only under Win98 (more rarely than before). I believe that the present versions of PSW are even better.
Don't worry, be happy ;-))))))))))))
Original Post ID: 10710
R.J.Hamlett
PostPosted: Wed Jan 15, 2003 11:46 am     Reply with quote
:=Hi,
:=You're not the only one (if this might calm you down).
:=I had the same troubles under Win98 and WinNT.
:=After updating PSW (IDE to 2.31 and PCM/PCH to 2.731) the things went better - the nice message box appears only under Win98 (more rarely than before). I believe that the present versions of PSW are even better.
:=Don't worry, be happy ;-))))))))))))
The message you are talking about, is common, _with the IDE_. However the original poster was talking about the command line interface.
I have run several 'old' versions of the compiler on W2K, and have not had this problem. However as another poster has said, I have seen this message when trying to compile a file with a syntax error.
The obvious suggestion then, is to verify this, by trying a 'minimal' program first. If this works without the error, the hard part is then working out which line is causing the problem...
Original Post ID: 10724
kolio
PostPosted: Thu Jan 16, 2003 1:54 am     Reply with quote
:=:=Hi,
:=:=You're not the only one (if this might calm you down).
:=:=I had the same troubles under Win98 and WinNT.
:=:=After updating PSW (IDE to 2.31 and PCM/PCH to 2.731) the things went better - the nice message box appears only under Win98 (more rarely than before). I believe that the present versions of PSW are even better.
:=:=Don't worry, be happy ;-))))))))))))
:=The message you are talking about, is common, _with the IDE_. However the original poster was talking about the command line interface.
:=I have run several 'old' versions of the compiler on W2K, and have not had this problem. However as another poster has said, I have seen this message when trying to compile a file with a syntax error.
:=The obvious suggestion then, is to verify this, by trying a 'minimal' program first. If this works without the error, the hard part is then working out which line is causing the problem...
:=Best Wishes
I see, you're right.
Original Post ID: 10735
