USART address detect
funmix
PostPosted: Wed Apr 25, 2007 10:33 am     Reply with quote
Any comment for the code? I am going to implement 9 bit addressable mode USART.
#case
#include <18F4520.h>
#define  FREQ_OSC 20000000
#define  BAUD_RATE   19200
#use delay(clock = FREQ_OSC)
#use rs232(baud=19200,xmit=PIN_C6,rcv=PIN_C7,ENABLE=PIN_C5,bits=8,parity=N)
#define  RS485_ENABLE   PIN_C5
#byte SPBRG = 0xFAF
#byte PIR1  = 0xF9E
#byte RCSTA = 0xFAB
#byte TXREG = 0xFAD
#byte RCREG = 0xFAE
#byte TXSTA = 0xFAC
#bit  TXIF  = PIR1.4
#bit  RCIF  = PIR1.5
#bit  CSRC  = TXSTA.7
#bit  TX9   = TXSTA.6
#bit  TXEN  = TXSTA.5
#bit  SYNC  = TXSTA.4
#bit  BRGH  = TXSTA.2
#bit  TRMT  = TXSTA.1
#bit  TX9D  = TXSTA.0
#bit  SPEN  = RCSTA.7
#bit  RX9   = RCSTA.6
#bit  SREN  = RCSTA.5
#bit  CREN  = RCSTA.4
#bit  ADDEN = RCSTA.3
#bit  FERR  = RCSTA.2
#bit  OERR  = RCSTA.1
#bit  RX9D  = RCSTA.0
int8 g_packet[40];
#define BUFFER_LEN    32
char  recchar = 0;
char  txvchar = 0;
#int_rda
void rda_isr()
   recchar = RCREG;
   if(OERR)
      CREN = 0;
      #asm
      nop
      #endasm
      CREN = 1;
void my_send(char cmd)
   while(!TXIF);
      TXREG = cmd;
char my_receive(void)
   int temp;
   int retval;
   while(!RCIF);
      temp = RCSTA;
      retval = RCREG;
         if(bit_test(temp,1))
               CREN = 0;
               CREN = 1;
   return(retval);
void init_uart(void)
   SPBRG = (FREQ_OSC/(BAUD_RATE*16))-1;
   TXSTA = 0x66;//0x26
   RCSTA = 0xD8;//0x90
void SendPacket(void)
   int16 hdr;
   char  cs = 0;
   char  i;
   output_high(RS485_ENABLE);
   TX9 = 1;
   TX9D = 1;
   hdr = 0x100 +g_packet[0];
   putc(hdr);
   TX9 = 0;
   TX9D = 0;
   for(i=1;i<BUFFER_LEN;i ++)
      cs+=g_packet[i];
      putc(g_packet[i]);
   putc(cs);
   output_low(RS485_ENABLE);
   char cmd;
  enable_interrupts(INT_RDA);
   init_uart();
   printf(my_send,"Sending out\n\r");
SendPacket()
  /* while(1)
   cmd = my_receive();
   my_send(cmd);
funmix
PostPosted: Thu Apr 26, 2007 2:05 am     Reply with quote
I have modifed the code..
below is the #int_rda routine, please comment
#use rs232(baud=19200,xmit=PIN_C6,rcv=PIN_C7,ENABLE=PIN_C5,bits=8)
#int_rda
void serial_isr()
  int t;
  char temp;
  ADDEN = 1;
  temp = RCREG;
  if(ninth_bit)
  if(temp == Node_Address)
   ADDEN = 0;
   receive_data()
kevcon
PostPosted: Thu Apr 26, 2007 6:50 am     Reply with quote
I think you neeed to start over, you are missing a few things and you have stuff you don't need.
You need a line as shown below for the compiler to setup the uart correctly.
#use delay( clock = 20,000,000 )
If you are using 9 bits you neet to set the uart correctly.
#use rs232 baud=19200,xmit=PIN_C6,rcv=PIN_C7,ENABLE=PIN_C5,bits=9)
You are duplicating things that are built in to the compiler.
This is taken care of by the #use rs232 line
   TXSTA = 0x66;//0x26
   RCSTA = 0xD8;//0x90
look at the CCS serial examples.
