Calibration message....
deepakomanna
View user's profile Send private message AIM Address Yahoo Messenger
PostPosted: Mon Apr 23, 2007 12:30 am     Reply with quote
Dear sir,
here i am using 12f629, MPLAB 7.5 Ver. & CCS PCM C Compiler, Version 3.249, 34534.
My query is, while i am programming one message box is appering
"Calibration Memory is Already Programmed"
but in my coding i declared,
[/code]
#use delay(clock = 4000000)
#byte OSCCAL = 0x90
#asm
CALL 0X03FF
MOVWF OSCCAL
#endasm
So plz tell me why it is showing this msg & this will affect in prog.
Thank You,
With Best Regards,
Deepak.
PostPosted: Mon Apr 23, 2007 12:45 am     Reply with quote
You probably have a #Rom statement in your program (not shown in your
post) that sets the OSCCAL value (at address 0x3FF) to some value.
MPLAB is informing you that it's not going to let you change the OSCCAL
value.
deepakomanna
calibration msg....
PostPosted: Mon Apr 23, 2007 1:53 am     Reply with quote
Thanks for replying,
But in my code i didn't not used #ROM like statement,
plz refer following code..
#include<12f629.h>
#fuses INTRC_IO,NOWDT,PUT,NOMCLR,PROTECT,NOCPD,BROWNOUT
#byte OSCCAL = 0x90
void init_CPU();
void DLY_CNT_FUNCTION();
void ON();
unsigned int16 RPM_COUNT;
int1 flag;
flag = 0;
RPM_COUNT = 0;
init_CPU();
      while(INPUT(PIN_A1));         //   Wait for Zero Pulse
         SETUP_TIMER_1(T1_DISABLED);      // TIMER_1 count OFF
         RPM_COUNT = GET_TIMER1();
         SET_TIMER1(0x00);
         SETUP_TIMER_1(T1_INTERNAL | T1_DIV_BY_8);      //TIMER 1 ON.
         if(flag == 1)
                ON();
      while(INPUT(PIN_A0));
         if(flag == 0)
               ON();
          DLY_CNT_FUNCTION();
flag = 1;
if((RPM_COUNT >= 4167)||(RPM_COUNT == 0) )      /*rpm < 1800*/
         flag = 0;
void ON()
/*=========== Turn ON FOR 60 usec =================   */
OUTPUT_HIGH(PIN_A2);
DELAY_US(60);
OUTPUT_LOW(PIN_A2);
void  init_CPU()
   PORT_A_PULLUPS(0x13);         // Enable pullups GPIO0,GPIO1,GPIO4 I/P &ALL O/P
   SET_TRIS_A(0x13);            //GPIO0,GPIO1 I/P & ALL O/P.
   SETUP_COMPARATOR(NC_NC_NC_NC);      // Make comparator off
   #asm
   CALL 0X03FF
   MOVWF OSCCAL
   #endasm
Thank You,
With Best Regards,
Deepak.
PostPosted: Mon Apr 23, 2007 2:11 am     Reply with quote
You don't need the #asm code to set the OSCCAL register. CCS does
it for you. Here is the code created by vs. 3.249 for your program:
0000 3000       00001 MOVLW  00
0001 008A       00002 MOVWF  0A
0002 2804       00003 GOTO   004
0003 0000       00004 NOP
0004 23FF       00005 CALL   3FF    // Get OSCCAL value in W
0005 1683       00006 BSF    03.5   // Bank 1
0006 0090       00007 MOVWF  10     // Register 0x90 = W
0007 3000       00008 MOVLW  00
0008 008A       00009 MOVWF  0A
0009 2843       00010 GOTO   043
This is put in by the compiler. It's not your #asm code.
deepakomanna
calibration msg...
PostPosted: Wed Apr 25, 2007 5:29 am     Reply with quote
Dear Sir,
Still it has problem.
I commented these lines which are used for OCCILLATOR CALIBRATION. in my code.
but still it is showing the message.
//#use delay(clock = 4000000)
//#byte OSCCAL = 0x90
// #asm
// CALL 0X03FF
// MOVWF OSCCAL
// #endasm
Thank You,
With Best Regards,
Deepak.
Thank You,
With Best Regards,
Deepak.
PostPosted: Wed Apr 25, 2007 1:15 pm     Reply with quote
My suggestion is to ask this question in the Microchip forum. That's
because the error message is coming from MPLAB and the programmer.
Ask them why it's giving the message.
Here is the ICD2 forum:
http://forum.microchip.com/tt.aspx?forumid=49
Here is the PicStart-Plus forum:
http://forum.microchip.com/tt.aspx?forumid=15
