having trouble with interrupt change on B
gpgames84
PostPosted: Tue Apr 24, 2007 9:14 am     Reply with quote
I'm having trouble getting the #int_RB working right
what i'm trying to do is use the pull internal pull ups to keep the pins high, and drive one pin low when i need to with a switch.
here is most of the code
what am i doing wrong
#define Latch PIN_A0
#define Buzz PIN_A1
#define tach  PIN_B5
#int_rb
void  changeonb_isr()
   output_low(Buzz);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   setup_oscillator(OSC_32MHZ);
  // setup_oscillator(False);
   port_b_pullups(TRUE);
   set_tris_e(!000);
   set_tris_b(0xFF);
   disable_interrupts(INT_RB);
   disable_interrupts(GLOBAL);
   output_low(Buzz);
   delay_ms(3000);
   output_high(Buzz);
   delay_ms(2000);
   output_low(Buzz);
   delay_ms(3000);
   output_high(Buzz);
   enable_interrupts(INT_RB);
While(true)
      delay_cycles(5);
      output_high(Buzz);
Buzz=PIN_A1 is connected to an led. when the pic first starts it will flash the led, but once interrupts are turned on, the led stays on permenantly, even though there is no change on any pin, and they are held up with internal resistors.
Any suggestions. Thanks a lot.
Edit: I guess I should have mentioned that this is for a PIC18F4520 and that im using compiler version 4.024 Thanks
PostPosted: Tue Apr 24, 2007 10:24 am     Reply with quote
The PortB 'change' interrupt, happens,whenever the state of PortB doesn't match the value stored in an internal latch.
Three things therefore need to be done:
1) You _must_ read PortB in the interrupt handler. Otherwise the latch will not be reset, and the interrupt will occur permanently.
2) Once any configuration is done to the pins (even something like turning on the pull-ups), you again _must_ read the port to reset the latch.
3) Before enabling the interrupt, and after reading the port, you should clear the interrupt flag, otherwise if the flag has been set, and interrupt will immediately occur.
rnielsen
PostPosted: Tue Apr 24, 2007 10:49 am     Reply with quote
Remember, this in an interrupt on _change_. This means that you will get an interrupt when a pin goes to a Low state. You will, also, get an interrupt when it returns to a High state. You'll get an interrupt every time it changes state so you'll need to be able to handle the return-to-normal state in the ISR.
Ronald
