Someone please help
teongkia
Someone please help
PostPosted: Sun Apr 22, 2007 11:54 pm     Reply with quote
Hi can anyone look at my code and tell me what is wrong with it?The basic operation is when I switch on the power supply, and when I supply 5V input in PIN_A4, it will enable the interrupt and triggering any sensors will trigger the siren at PIN_B5 and dial the specific number. But when I switch on the power supply, the siren(PIN_B5) has 5V output immediately without triggering any sensor.And my remote control does not work too.Anyone can help?Thanks.
//Preprocessor
#INCLUDE <16F877.H>
#FUSES HS,NOWDT,NOLVP
#USE DELAY(clock=12000000)
#USE RS232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
//Define pin
#DEFINE SIREN     PIN_B5
#DEFINE CL1   PIN_B4
#DEFINE CL2       PIN_B3
#DEFINE ULTRA   PIN_A0
#DEFINE TOUCH     PIN_A1
#DEFINE LIGHT     PIN_A2
#DEFINE DOOR      PIN_A3
#DEFINE REMOTE  PIN_A4
//Global declaration
int A,B,C,D,RC,EN;
int RC1[2];
char SENSOR1, SENSOR2, SENSOR3, SENSOR4, TEMP;
char S[51];
//Sound siren
void SIREN_ON()
   OUTPUT_HIGH(SIREN);
   DISABLE_INTERRUPTS(INT_RTCC);
//Unlock doors
void UNLOCK()
   OUTPUT_HIGH(CL1);
   OUTPUT_LOW(CL2);
//Lock doors
void LOCK()
   OUTPUT_LOW(CL1);
   OUTPUT_HIGH(CL2);
//Ultrasonic sensor triggered
void SEND_CALL1()
   PRINTF("ATD0166827272;\n\r");
//Touch sensor triggered
void SEND_CALL2()
//Light sensor triggered
void SEND_CALL3()
//Door sensor triggered
void SEND_cALL4()
//Central lock triggered
void SEND_CALL5()
#INT_RTCC
T0()
      SENSOR1=INPUT(ULTRA);
      SENSOR2=INPUT(TOUCH);
      SENSOR3=INPUT(LIGHT);
      SENSOR4=INPUT(DOOR);
   if(SENSOR1)
         SEND_CALL1();
         SIREN_ON();
      else if(SENSOR2)
         SEND_CALL2();
         SIREN_ON();
      else if(SENSOR3)
         SEND_CALL3();
         SIREN_ON();
      else if(SENSOR4)
         SEND_CALL4();
         SIREN_ON();
//Main function
void MAIN()
     SET_RTCC(0);
     SETUP_COUNTERS(RTCC_INTERNAL,RTCC_DIV_64);
   EXT_INT_EDGE(0,H_TO_L);
     ENABLE_INTERRUPTS(INT_RDA);
    ENABLE_INTERRUPTS(GLOBAL);
     SET_TRIS_A(0b00011111);
     SET_TRIS_B(0x01);
   //SET_TRIS_C(0x0F);
   SET_TRIS_D(0x00);
     DELAY_MS(5000);
   PRINTF("\n\rATZ\n\r");
   DELAY_MS(500);
     PRINTF("\n\rAT\n\r");
   DELAY_MS(500);
   PRINTF("\n\rAT+CNMI=2,3,0,0,0\n\r");
   DELAY_MS(500);
   SENSOR1==0;
     SENSOR2==0;
     SENSOR3==0;
     SENSOR4==0;
   A=0;
   B=0;
   C=0;
   D=0;
   EN=0;
     RC=0;
     UNLOCK();
     //Checking system activation
       RC=(INPUT(REMOTE)^0);
      RC1[0]=RC;
      //Checking for rising and falling edge
      if((RC1[0]==1 && RC1[1]==0)||(RC1[0]==0 && RC1[1]==1))
         EN=(EN^1);
         if(EN==1)
             LOCK();
            ENABLE_INTERRUPTS(INT_RTCC);
            UNLOCK();
      RC1[1]=RC;
PostPosted: Mon Apr 23, 2007 12:23 am     Reply with quote
I didn't really look at your program design. I looked for simple problems,
and there are several of them.
The lines shown below are incorrect. You want to initialize these
variables, but you're using the wrong operator. You should use the
assignment operator, which is a single equal sign: '='
SENSOR1==0;
SENSOR2==0;
SENSOR3==0;
SENSOR4==0;
Below, you're setting the TRIS, but you're not using "fast i/o" mode,
which is specified with a #use statement. My advice is to use
"standard i/o" mode (it's the default mode). Delete these TRIS
statements and let the compiler handle the TRIS. If you use CCS i/o
functions such as output_low(), output_high(), input(), etc., the compiler
will set the correct TRIS automatically for you.
SET_TRIS_B(0x01);
//SET_TRIS_C(0x0F);
In addition to that, you should use output_low() or output_high()
statements to initialize all your output pins to their preferred initial state.
For example, if you want the SIREN pin to be initially low (i.e., OFF), then
put this line of code near the start of main():
output_low(SIREN);
Do the rest of your output pins the same way. You don't have to
do anything to your input pins, because all PIC i/o pins come up
configured as inputs upon power-on reset.
Here, you're enabling RDA interrupts, but you don't have an #int_rda
interrupt service routine anywhere in your posted code. This is wrong.
Here, you have an interrupt service routine for the RTCC timer, but
you don't have a line of code in main() to enable the INT_RTCC
interrupt. Perhaps you meant to type in INT_RTCC in the code above
but you typed in INT_RDA by mistake.
#INT_RTCC
T0()
etc.
teongkia
PostPosted: Tue Apr 24, 2007 7:40 am     Reply with quote
Thanks. I tried edit the code and tested it. But there are still some problems. The first problem is without triggering the remote pin, triggering the input sensor will trigger the output siren pin. What I want is only after I trigger the remote pin, it will enable the RTCC interrupt and then triggering any of the input sensor pin will have 5V output in siren pin.
The second problem is triggering the input sensors pin would make a call through the mobile phone while sometimes not. Can you solve my problems? Thanks.
//Preprocessor
#INCLUDE <16F877A.h>
//Define pin
#DEFINE CL1       PIN_B4
#DEFINE CL2       PIN_B3
#DEFINE REMOTE    PIN_A3
#DEFINE DOOR      PIN_A4
int A,B,C,D,RC,EN;
int RC1[2];
char SENSOR1, SENSOR2, SENSOR3, SENSOR4;
char S[51];
//Sound siren
void SIREN_ON()
   OUTPUT_HIGH(SIREN);
//Unlock doors
void UNLOCK()
   OUTPUT_HIGH(CL1);
   OUTPUT_LOW(CL2);
//Lock doors
void LOCK()
   OUTPUT_LOW(CL1);
   OUTPUT_HIGH(CL2);
void SEND_CALL1()
void SEND_CALL2()
void SEND_CALL3()
void SEND_cALL4()
void SEND_CALL5()
#INT_RTCC
T0()
   if(SENSOR1)
         SEND_CALL1();
         SIREN_ON();
      else if(SENSOR2)
         SEND_CALL2();
         SIREN_ON();
      else if(SENSOR3)
         SEND_CALL3();
         SIREN_ON();
      else if(SENSOR4)
         SEND_CALL4();
         SIREN_ON();
//Main function
void MAIN()
     SET_RTCC(0);
     DELAY_MS(5000);
   DELAY_MS(500);
   DELAY_MS(500);
   DELAY_MS(500);
   SENSOR1=0;
     SENSOR2=0;
     SENSOR3=0;
     SENSOR4=0;
   OUTPUT_LOW(SIREN);
   A=0;
   B=0;
   C=0;
   D=0;
   EN=0;
     RC=0;
     UNLOCK();
      RC1[0]=RC;
         EN=(EN^1);
         if(EN==1)
             LOCK();
            UNLOCK();
      RC1[1]=RC;
PostPosted: Tue Apr 24, 2007 8:54 am     Reply with quote
If you don't want the RTCC interrupt to be enabled at start up... than don't call enable_interrupts(INT_RTCC) at the start of main but use disable instead.
