compiler 4.023 bug compare with compiler 3.18 ???
eblin
PostPosted: Tue Apr 24, 2007 12:20 am     Reply with quote
i had a programm working fine with pcm 3.18 , using ccp1 and ccp2 interrupts on a pic16f876 .to mesure time between pulses. I converted it with compiler 4.023 , on the same hardware, and it doesn't works (i have hazardous results). Is there some differences between those 2 compilers?? Question Question Question
thanks for any help
PostPosted: Tue Apr 24, 2007 12:27 am     Reply with quote
CCS changed the behavior of the "address of" starting with vs. 4.021.
This may affect your code in several ways. Read these posts:
http://www.ccsinfo.com/forum/viewtopic.php?t=27714&start=196
http://www.ccsinfo.com/forum/viewtopic.php?t=30461
http://www.ccsinfo.com/forum/viewtopic.php?t=30393
eblin
understood
PostPosted: Mon Apr 30, 2007 4:38 am     Reply with quote
thanks,
i understand now better differences between v4 and v3
philippe
