INT_RTCC RTCC timer0 going too slow on 18F2520
evsource
PostPosted: Mon Apr 23, 2007 10:27 am     Reply with quote
On a 18F2520, with the latest version compiler (4.030), I can't seem to get the timer0 interrupt (INT_RTCC) to give the expected results. I have it set up like this:
setup_timer_0( RTCC_INTERNAL );
enable_interrupts(INT_RTCC);
I've tried variations of the setup_timer0 function using various combinations like:
setup_timer_0( RTCC_INTERNAL | RTCC_DIV_2);
and
setup_timer_0( RTCC_INTERNAL | RTCC_DIV_128 );
I'm using a 8mHz clock.
The higher divisors do slow the interrupt down, but the fastest setting (the first chunk of code with only RTCC_INTERNAL, no scalers), interrupts at about 14Hz. I would expect *much* faster.
Any ideas of what I could be doing wrong?
PostPosted: Mon Apr 23, 2007 11:22 am     Reply with quote
The timer is being configured in 16-bit mode. You're probably expecting
it to be in 8-bit mode. In CCS, you have to explicitly put it in that mode.
Example:
setup_timer_0( RTCC_INTERNAL | RTCC_8_BIT );
evsource
PostPosted: Mon Apr 23, 2007 3:50 pm     Reply with quote
Example:
That was it. Thanks!
